Most likely not. I've been repairing the 1300 series for several years and I've never seen it. The older units would say "battery charge complete". I would go by the green battery icon in the upper right corner of the screen at the main menu. There should be 4 green bars to be fully charged. Of course to see them, you have to unplug the charger.
SOURCE: not knowing when my nuvi 250 is fully charged
if the greens bars on the upper right indicates fully charged
SOURCE: My Garmin Nuvi 710 GPS doesn't switch on
Connect your Nuvi to a PC using a USB and then hold the switch to the left for 15 seconds. It should then power up after a soft reset
SOURCE: My Garmin Nuvi 200 won't turn on/fully charged
If it is not charged it will not turn on. If you have a bad battery (which is the case if it won't fully charge) your only choice is to return to Garmin.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the
StreetPilot C300 and C500 series do not have user replaceable batteries. These
units must be sent in to a Garmin approved repair facilities if a battery
issue arises. Garmin and Raytech are the
only Garmin approved repair facilities. Raytech is a repair
facility for Canadian customers. To
repair your device please contact the specific repair facility for your region.
If your device is not still under the 1 year warranty, there will be a cost
associated with the repair of your device. Go here for repair:
http://www8.garmin.com/support/outofwarranty.html
SOURCE: Upon turning my Garmin Nuvi 1300 on it sticks on
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is
acting erratically is symptomatic of having corrupt
firmware.
To
correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck,
then updating your Nuvi firmware.
Follow
these three steps to take to get
your Garmin Nuvi 1300
running like new:
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
SOURCE: My garmin nuvi 1300 won't turn on. It should be
firmware.
To
Follow
running like new:
I hope that helps.
