SOURCE: Need the pin assignments for the mother board
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site (ASUS) to download a manual, the manufacturer and model number is printed on the motherboard.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
