SOURCE: calendar creator 12 is not loading / not working
try right clicking the icon and run as administrator see if that allows you to work with it, might try setting it to run as adminisrator anways, right click, click properties, and look thru tabs and choose run as administrator...hope this helps...shia
SOURCE: program won't run
Hello ccsstjoe,
Download Revo-Uninstaller, find Calendar Creator 12 in the list of programs and click on it(highlight it). Then from the menu at the top, select 'Uninstall'. On the next screen, select 'Advanced Mode' then Next. After prompting(as directed) through the removal process, reboot your PC and then reinstall CC12. If that doesn't work you may want to return/exchange for something different.
SOURCE: I HAVE A NEW COMPUTER WITH WINDOWS 7. I CANNOT
Check to see if the cd is compatible with windows 7. It might not be. If it isn't check the website of the manufactorer to see if they have a download. If they do you can make that download compatible on a windows 7 machine.
If you have windows 7 professional version you can install xp and then put the disk on the xp part of windows 7.
SOURCE: very slow in loading pics and clipart to the
Lots of information missing here, but at a guess, you have a nasty bug.
Do a full scan of your system for viruses, rootkits, spyware, and everything else you can think of.
If you need these tools, check out Gizmos site for a mob of free security software and advice.
SOURCE: Will Calendar Creator 12 work with Windows 7
Yes and no. Calendar Creator 12.1 will work with Windows 7 - 64 bit, but the PDF converter will not. So you can't save your files in pdf format and have them printed externally.
The traditional method --- uninstall Broderbund Calendar Creator with windows add/remove program
1. Start-->Control Panel-->Add/Remove Programs.
2. Find Broderbund Calendar Creator in the program list and right click to choose Delete.
3. Follow the panel wizard and reboot your PC when it finished.
In fact this way can not remove all the components of Broderbund Calendar Creator. Registry keys of Broderbund Calendar Creator still remain on your computer. It is advised to clear up registry entries of Broderbund Calendar Creator or you are likely to encounter problems like uninstall or install error, registry error and so on.
Guaranteed Method -- Uninstall Broderbund Calendar Creator with a professional uninstall tool
A third party uninstall program can force uninstall Broderbund Calendar Creator while windows add/remove program fails. Moreover, a third party uninstall program can clear up all the registry entries of Broderbund Calendar Creator. Among so many uninstaller tools, Perfect Uninstaller enjoys high reputation. Perfect Uninstaller can remove Broderbund Calendar Creator completely in 4 simple clicks.
1. Free download Perfect Uninstaller form its official website.
2. Install Perfect Uninstaller on your computer
3. Browse for Broderbund Calendar Creator folder with Perfect Uninstaller.
4. Click REMOVE to uninstall Broderbund Calendar Creator from your computer.
It is important to uninstall Broderbund Calendar Creator thoroughly from your computer, as its remained components will have a side affect on your current antivirus program. Are you tired of trying various methods to uninstall Broderbund Calendar Creator? Do you want a certain effective way to uninstall Broderbund Calendar Creator? What you really need is a third party uninstall program. And before you search for a great uninstall program, have a look at Perfect Uninstaller and then compare it with the other one
Read more: http://www.articlesbase.com/software-articles/how-to-uninstall-broderbund-calendar-creator-thoroughly-from-your-pc-now-3769861.html#ixzz1CrBj3PaU
Under Creative Commons License: Attribution
