All cash registers can be programmed NOT to open on the No Sale button. It is a way to open up ***** and under-ringing / pocketing the money handed over by pressing N/S instead of an amount.
Royal Consumer Information Productshttps://www.royal.com > cashreg > Instruction ...
DOC
Royal's helpful "Quick Start" program (Page 12) will provide you with the most basic programming options for the operation of your new cash register.
Replacement Journal Paper Roll Spindle: 105...
Protective Keytop Cover: 013221
Item Description: Part Number
If the Sharp ER-A320 cash register has lost its settings after being unplugged and plugged back in, you may need to reprogram the register. Here are some steps you can follow:
Consult the user manual: The user manual for the ER-A320 should have instructions for programming the register. If you don't have a physical copy of the manual, you can search for it online or contact Sharp customer support for assistance.
Check the backup battery: The ER-A320 has a backup battery that helps to retain the programming in case of a power outage or unplugging. If the battery is dead or weak, it may have contributed to the loss of settings. You can check the battery and replace it if necessary.
Reprogram the register: Using the manual or instructions provided by Sharp, you can reprogram the register with the necessary settings. This will likely involve resetting the register, entering your store information, setting up departments, programming PLUs, and setting up tax rates.
Test the register: Once the programming is complete, you should test the register to make sure it is functioning properly. You can perform test transactions and ensure that the correct receipts are printed and that the totals are correct.
If you are not comfortable reprogramming the register yourself, you can contact a Sharp authorized service center for assistance.
The software is not needed to program the register. It is only needed if you have a special bitmap file to upload to the register. The manual tells you how to program everything through the cash register keyboard.
For those who requested the Sharp XE-A203 manual, one of the users has it here: http://the-checkout-tech.com/manuals/cashregisters/Sharp12.php
To get the manual for windows 7, search windows 7 on microsoft.com
What do you mean by register? To activate and register windows or to register you dell computer?
