SOURCE: Wiring Diagram
First, try looking here: http://www.crutchfield.com/learningcenter/car/amplifiers_movie.html If that helps, be sure to leave feedback or I don't get paid. Look all over the cruchfield page and you can find guides for every type of installation.
SOURCE: My Kenwood KAC-X1R hooked up to (2) Kicker Solobaric L5's
first get a deck with 4 volt pre outputs or more that will help a lot then a battery in the back will help like a 1000cca or more
SOURCE: problem with LEGACY BLUE DIAMOND AMPLIFIERS LA1080
never attemp to bridge your amps specially this type of amps. this are too very complicated. you may blow your amp if you will attempt it again.
SOURCE: my kenwood amp
you need to check your wiring and check your rca wires to see if they are giving your amp a signal to put out
SOURCE: wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
