Try resetting the camera.. 1.0 Turn off the camera 2.0 Remove the battery 3.0 Leave it for at least 15 min. Start again... Good luck
If you can play back captured images without any problem then your camera has a faulty CCD sensor. If you can get hold of a new CCD sensor block for this model somehow then you can install it yourself. Otherwise camera has to go to your Nikon agent.
All thing and function is work properly by screen is black why
SOURCE: Blank screen while taking pictures
Sure this is a clear case of faulty CCD sensor if you can play back captured images ok. Parts and labor will set you back by +- $ 200 if you have it done professionally.
