Question about Leviton 1755 Triple Rocker Switch Decora
How do i wire a leviton 1755 - Leviton 1755 Triple Rocker Switch Decora
4 Suggested Answers
SOURCE:
  • 21326 Answers
SOURCE: I'm using a Leviton 1755 combo 3 switch for a bath
remove white switch one and connect to incoming white ground--all whites should be connected [hooked] together these are grounds-- switch 1 black from fan ,leave switch 2 red from fan ,switch 3 vanity black
Posted on Feb 22, 2010
SOURCE: I need to find leviton 1755 in brown
You could use 3 brown single-pole despard switches
Otherwise I cannot find source for triple rocker in brown.
Posted on May 09, 2011
cool78259
  • 228 Answers
SOURCE: I have a 12/2 (black/white/ground)
The switch that you have works like 3 seperate switches. most of these switches will have gold screws
on one side and silver screws on the other side, lets say that the left is gold and the right is silver, and
the switch may also have a green screw for ground. your 12/2 with ground is your main hot, you may
want to mark it with a piece of tape, so you know it's the incoming hot. the ground off your hot will tie,
to the green screw on switch and continue and tie to your vent light which should also have a ground
the white coming off the hot is your neutral, it will go straight to your white or whites on your heater.
the black hot wire at your switch will go to each gold terminal on one side of the switch,there are two
ways you can do this, go to one side and just run a jumper, or put one wire on each gold screw and
tie in to your hot-black wire with a wire nut. now for the switch legs, you will need to run from your, switch
to your heater either another pair of 12/2s or a 12/3, each side of the switch that has one silver screw,
it's easier with a 12/3 normally a 12/3 will have a red,black,white,and ground.
top switch red to red on heater,black to black on light and the white blue on the vent,so from your switch
to the heater you would have to run a12/2 you would not use the black only the white and ground.
remember the white-neutral coming from the switch will be tied to all the whites at the vent,light,heater
except for the 10/3. the 10/3 is used stricktly for the switch legs. good luck!
Posted on Jul 10, 2011
Wiring diagram for levinton 1755 switch
http://waterheatertimer.org/How-to-wire-switches.html#triple
Triple switch wiring with neutral in box and neutral in light fixture
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 11, 2014 | Leviton 003-1755-W Three Rocker Switches
How to wire tree seperate lights
Not sure from your description.
Copy following link:
Add a comment for follow-up
Mar 24, 2013 | Leviton 1755 Triple Rocker Switch Decora
How do i hook up 3 function switch
1) Copy following link to see wiring diagrams:
2) There are two basic wiring type, depending if power wire and neutral arrive in switch box first, or power wire and neutral arrive in ceiling box.
3) Most homes, the power wire is in ceiling box.
In this case, a minimum of 4 wires are needed between ceiling box and switch.
Dec 09, 2012 | Leviton 1755 Triple Rocker Switch Decora
Apr 30, 2011 | Leviton 1755 Triple Rocker Switch Decora
How do i wire a miniature rocker switch red/brown and black wires
Any wire that is colored is hot, except for green and white, which is ground and neutral, If you have a line coming in to your switch, and 3 loads going out, red, brown, black, then those should be the 3 lights. The white wire will be connected to white, and the green to ground. If you don't have 4 colored wires, then you have 1 switch too many. Let me know if this is making sense.
Apr 14, 2010 | Leviton 003-1755-W Three Rocker Switches
I'm using a Leviton 1755 combo 3 switch for a bath light/fan combo and then onto a vanity light. Basics: wires from ceiling light/fan: black, red, white, ground. Wires to vanity light: black, white,...
Feb 22, 2010 | Leviton 003-1755-W Three Rocker Switches
Not sure how to wire this switch
Switch will have a commom terminal that the hot wire connects to.
The other three terminals are for the devices -- light, fan and other device.
The white wires should be the grounded wire returns for the circuits unless they are identified by color tape to be hot line side of power.
Be careful of the grounded side of circuit, can shock or kill, treat all wires as being energised. If you are not sure, use a electrical tester,
or get help.
Feb 28, 2009 | Leviton 003-1755-W Three Rocker Switches
Leviton 1755 Triple Rocker Switch Decora Logo
166 people viewed this question
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
