Computers & Internet Logo
Posted on Apr 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My half of the keypad(Right Side) not working
My half of the keypad(Right Side) not working properly, example i have to type i that time i Use fu+i =i Otherwise not typing i
  • Anonymous Apr 16, 2009
    Only part of the keyboard working
  • Anonymous Apr 20, 2009
    i too have the same problem but only the power button works rest all doesnt.. please help
Anonymous
Level 2:
  • Expert 38 Answers
  • Posted on Aug 03, 2009
Anonymous
Expert
Level 2:
Answers
38
Questions
Helped
32205
Points
163
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start my half of the  keypad(Right Side) not working - c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .my half of the keypad(Right Side) not working - c01311985.jpg/a> Figure 4: Add button
  5. Select the keyboard(s) you want to use and click my half of the keypad(Right Side) not working - c01311986.jpgbr /> Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the sysmy half of the keypad(Right Side) not working - c01311987.jpgowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Lamy half of the keypad(Right Side) not working - c01311988.jpgw, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
  8. If required reinstall the drivers
  • Anonymous Aug 03, 2009
        Click Start , and type region into the Start Search field.
              Click Add .
                Select the keyboard(s) you want to use and click OK .
                The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
                  From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
How do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
1helpful
I have fujitsu laptop runing win 7, when i type some letter be wrong for examle when i type m come 0 ,
Hello there,
Did you check the keypad for alternate keys.
For example net books, the number keys on the right side has an alter key on the some letters like the image below. when you accidentally press the [Fn] key, Numbers are written instead of letters..
Hopefully this helps. Thank you for posting..
My touch screen is about half inch out of sync. If I type a 6 I get a 5 and if i type a 5 i get a 4. I cant get anything on the right side of the screen. I have tried the calibration button but I cant...
all you have to do is back up your phone, contacts, messages, and images, everything that needs backing up..
since calibration doesn't work now, one way to help you is to brought it back to it's factory default settings, be reminded that this will lose all user settings..
to do this, all you have to do is remove your sim, and memory card.. and on your keypad, as if you are making a call, type the following codes.. *2767*3855# it will bring your phone back to its factory settings.. once finished, reinsert everything, sim and battery and memory card..
if somehow this doesn't help you.. send it to your nearest service center for proper diagnosis and recommendations.. :) goodluck..
The front keypad does not work properly. When Press the keys on the right side of the keypad, both the center and right side show up. For example, try to press the 2 and you get 23, try to press the 3 and...
I believe you have water damage my friend what you can do is either bring it in for repair which probably would cost a good amount of money since there is water damage or you could try opening it up yourself and seeing if you could dry it or check out the damage yourself now if it keeps doing this you might need a new keypad I go to http://cnn.cn for my cellphone parts they usually have a great selection of stuff that is OEM and other items of that sort.
Cheers,
Kyle
Jul 10, 2009 • Cell Phones
2helpful
3answers
Can you tell me how to access the front touch-screen full-keypad?
You can only have the front screen touch keypad when you touch twice (double click) in the area where you want to type. (for example when you browse on the internet, text messaging or adding contacts). If you can't use the touch keypad the phone will tell you (for example in MSN messenger, you have to work with the keypad inside the phone).
SPH-M620 waterdamage
I got mine open, just take the 4 screws out and work your finger nail or something thin into the seam and work it around till the video side panel pops off. you can then see the batery, which mine seams fu*ked, wont work with out the charger plugged in. im trying to take it apart further but seams that there is some adheasive on the keypad side.
2430 dl paper alot of paper stuck
Hello
best way to check FU is take it out from printer,
first remove backside and left side cover, in backside there is a 4 small wires with 2 pin connectors you have to unplug connector, in left side there is a bigger withe and black wires, you have to unplug connectors. then open cover and remove *PC drum, also remove transferbelt, first remove 2 screws, 1 screw at each side, then unplug connector upper right and lift and remove transfer belt.
BE VERY CEARFUL WHEN OPERATING WITH TRANSFERBELT. DO NOT DAMAGE THE BELT.
then you cand remove 2 screws at each side of fusing unit, when moving the whole FU to right /maybe left, dont remember/ you can bull out the fusing unit. its a little tricky to take it out.
when you got the FU in your hands, you can inspect it, remove any paper, stuck. AGAIN, BE VERY CEARFUL, DO NOT DAMAGE THE RED ROLLER AND DO NOT USE ANY SHARP THINGS.
when needed you can also remove a few screws at the fusing unit and then you can take the fu a part to see whats wrong.
good luck.
2answers
Paper jams at fusion stage
I keep getting paper jammed at the fuser every single attemp to print. It's difficult to remove and the paper often tears when trying to pull it out.
This is most annoying since the printer is just outside of warranty and i just bought a new black toner cartridge. They don't make this printer anymore and I'm afraid the cost to repair would most likely exceed $200.
Looks like I have a nice new boat anchor now :(
Grand Canyon Tech
Grand Canyon Tech
