Motorola Mobility Droid RaZr XT912 16GB SmartPhone Cdma Verizon Logo
A
Anonymous Posted on Sep 10, 2013
Engineer mode - Motorola Mobility Droid RaZr XT912 16GB SmartPhone Cdma Verizon
04 grand prix gt keeps getting reduced engine power sensor
reduced engine power sensor ??? There is no reduced engine power sensor, Now a message on the DIC -driver information center, reduced engine power is a different story . Reduced Engine Power Refer to Powertrain Control Module Description in Engine Controls
Reduced Engine Power Mode
When the PCM detects a condition with the TAC system, the PCM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
• Acceleration limiting--The PCM will continue to use the accelerator pedal for throttle control; however, the vehicle acceleration is limited.
• Limited throttle mode--The PCM will continue to use the accelerator pedal for throttle control; however, the maximum throttle opening is limited.
• Throttle default mode--The PCM will turn off the throttle actuator motor and the throttle will return to the spring loaded default position.
• Forced idle mode--The PCM will perform the following actions:
• Limit engine speed to idle by positioning the throttle position, or by controlling the fuel and spark if the throttle is turned off.
• Ignore the accelerator pedal input.
• Engine shutdown mode--The PCM will disable fuel and de-energize the throttle actuator.
You need to hook up a scan tool an check for DTC'S - diagnostic trouble codes .
XL. Why is 'reduce eng.' light on?
Reduced engine power is a problem with the electronic throttle control . You need to have a scan tool hooked up to read codes stored .
REDUCED ENGINE POWER: Refer to Powertrain Control Module Description in Engine Controls - 4.8L, 5.3L, and 6.0L
When the PCM detects a problem with the throttle actuator control (TAC) system the PCM enters one of the following Reduced Engine Power Modes:
• Acceleration Limiting--The control module will continue to use the accelerator pedal for throttle control, however the vehicle acceleration is limited.
• Limited Throttle Mode--The control module will continue to use the accelerator pedal for throttle control, however the maximum throttle opening is limited.
• Throttle Default Mode--The control module will turn off the throttle actuator.
• Forced Idle Mode--The control module will perform the following actions:
- Limit engine speed to idle by positioning throttle position, or by controlling fuel and spark if throttle is turned off.
- Ignore accelerator pedal input.
• Engine Shutdown Mode--The control module will disable fuel and de-energize the throttle actuator.
Check engine and service traction control light on in 3rd limp mode
Check engine light on , check DTC'S - diagnostic trouble codes ! Check Engine Light On If not familiar with this take it to a ASE certified repair shop or dealer . 3rd limp mode ? Do you have a message in the DIC - driver information center , reduced power mode ?
ENGINE POWER IS REDUCED
Engine Control Module Description for the 4.8L, 5.3L, 6.0L and 6.2L engine
My 2006 Buick lacrosse reduce power light came on today--what does that mean
Refer to Throttle Actuator Control (TAC) System Description in Engine Controls - 3.6L or Throttle Actuator Control (TAC) System Description in Engine Controls - 3.8L
TAC System Default Actions/Reduce Power Modes
There are 2 reduce power modes that the engine control module (ECM) can default to if an error is detected in the throttle actuator control (TAC) system. If an accelerator pedal position (APP) sensor 1 or APP sensor 2 circuit fault, throttle position (TP) sensor 2 circuit fault, or if a TP sensor 1 circuit fault is detected with some APP angle, the ECM goes into one of the 2 reduce power modes. In this mode, the engine torque is limited so that the vehicle cannot reach speeds of more than 100 km/h (60 mph). The ECM remains in this reduce power mode during the entire ignition cycle even if the fault is corrected.
If there is a condition with the throttle actuator control circuits, throttle actuator command vs actual position fault, return spring check fault, or a TP sensor 1 circuit fault, the ECM goes into the other reduce engine power mode. In this mode, the engine speed is limited to 2,500 RPM and the 3-6 fuel injectors are randomly turned OFF. At this time the Reduced Power indicator is commanded ON. The ECM remains in the reduce power mode during the entire ignition cycle even if the fault is corrected. Observe, if a TP sensor 1 or throttle actuator control circuit fault is present at the time the vehicle is at idle, with no accelerator pedal angle, the engine may stall.
2003 Chevy Trailblazer engine power lose light come on
Hi Steve , your vehicle has electronic throttle control . I don't know if you are aware of this. The gas pedal have position sensors an a wiring connector with 4-6 wires .these wires are connected to the engine computer . an there is a electric motor on the throttle body assembly , the computer opens an closes the throttle . You probably have codes stored in the engine computer .
Reduced Engine Power Mode When the PCM detects a condition with the TAC system the PCM may enter a reduced engine power mode. Reduced engine power may cause one or more of the following conditions:
Acceleration limiting--The control module will continue to use the accelerator pedal for throttle control; however, the vehicle acceleration is limited.
Limited throttle mode--The control module will continue to use the accelerator pedal for throttle control; however, the maximum throttle opening is limited.
Throttle default mode--The control module will turn off the throttle actuator motor and the throttle will return to the spring loaded default position.
Forced idle mode--The control module will perform the following actions:
Engine shutdown mode--The control module will disable fuel and de-energize the throttle actuator.
Drive by Wire Function and diagnostics by Wells
Hello I have a 1994 maxima manual transmision,it have a check engine light on,when I start the car and beguin to drive it,runs perfect the a few minutes later the car gets very lazy almost want to turn...
Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.
  • Remove the trim panels in front of the center console. Locate the engine computer attached to a floor-mounted bracket on the transmission tunnel between the console and the firewall.
  • Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
    Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
    Code 11 Crank sensor angle
    Code 12 Mass airflow sensor
    Code 13 Engine coolant temperature sensor
    Code 14 Vehicle speed sensor
    Code 21 No ignition reference
    Code 22 Fuel pump
    Code 31 Engine control unit
    Code 32 EGR sensor
    Code 33 Oxygen sensor
    Code 34 Knock sensor
    Code 35 EGR temperature sensor
    Code 43 Throttle position sensor
    Code 45 Injector leak
    Code 51 Injector circuit
    Code 54 Automatic transmission signal
    Code 55 No malfunction recorded
    I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
    1helpful
    Warning: fail safe engine mode
    I do not know about a Jag. But the "fail safe engine mode " on my GMC means the Engine Controll Computer has quit working.
    Top Motorola Mobility Computers & Internet Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
