Nextar Q4-04 Car GPS Receiver Logo
Vicky Waller Posted on Sep 10, 2013
Warning box comes up and says can't start the main navigation engine
cristian romero
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 22, 2013
cristian romero
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
57
Points
Actualizae mapas de argentina
2answers
All warning lights came on and will not start, it just died, could it be the Alternator?
You need to have it tested ! Along with the battery as well .
2004 PT Cruiser lost power then died, wont start now.
If no check engine comes up, it would be PCM. PCM must set CHECK ENGINE LAMP when IG on.. Also check other instrument panel warning lamp come up. If not, Main Ampere Fuse must be checked.
Where is the fuse for alternatoron2004 navigator light on dash comes on after alternator has been changed
If the thick black and orange wire does not have battery voltage, there is a fuseable link near the battery or starter that is melted.
Same thing with the smaller orange and lite blue wire.
The smaller wires involve the computer and the instrument panel warning light.
Car engine light comes on and the car just stops
what car is it sounds like air in diesel or electrical fault to fuel pump
2helpful
My 2002 v8 lincoln navigator starts but wont stay on...the motor shakes real bad and then cuts of...it just started today...what could it be??
These problems can cause by several different reasons,
Engine needs air-fuel and sparks to keep running.
Ignitions and fuel system inspections will be good place to start and if you have any engine warning light on your dash the best thing to get the code read out to get first idea what is causing the problems you have!!
AUTO warning light comes on - 2004 Renault Scenic Petrol Auto
Auto warning light comes on but goes off when car stopped and restarted. Temp also goes higher
3helpful
2answers
Started and efi light come on what is it
The EFI should come on for about 5 seconds. If it stays on, you are about to lose the rectifier, battery and halogen headlight. When the EFI light stays on, it's telling you that the rectifier is failing. If you continue to oiperate the bike, it WILL quit. It will cook the battery and leave you stranded.
8helpful
Pace Sky plus box
You have 2 choices, software reset or hardware reset. It's up to you what you try, but please read the advice in full before starting - if you break your box, please don't blame me!
SOFTWARE RESET
The following is copied from http://www.ecademy.com/node.php?id=73309
This is useful if your disk usage percentage doesn't go down even after clearing programmesfilms off.
The following is offered on an ADVICE only basis, take care when making changes:
WARNING following this advice is totally at your discretion and anything which happens to your digibox as a result is your responsibility, not mine. You will lose all recorded programmes from your Sky+ Planner.
Sky tech support can talk you through performing a system restore over the phone. To do this yourself, press 'services' on your Sky plus remote, then select option 4. Next press 0, 1, select - you should now see the engineer's menu. Choose option 8, 'Full System Reset'. The box will now take a few minutes to reset itself
Try pausing or recording again, and if the problem persists disconnect the digibox from the mains power. Press and hold the 'left' and 'right' navigation buttons on the front of the digibox whilst you reconnect the mains power. Continue holding the buttons in for about 20 seconds, and when the ring of light on the front comes on, press the 'select' button on the front of the digibox (between the left and right buttons you were holding). The Sky+ recording logo lights will spin backwards and, according to the Sky engineer, this will "clear the hard drive".
Once this is done, disconnect the digibox from the mains power again and this time press and hold the 'back up' button whilst you reconnect the mains power. Continue holding it for about 15 seconds until 3 lights on the front of the box come on and you get a full-screen message saying "Updating system software. Do not disconnect mains supply or satellite dish."
Leave the digibox doing its thing for about 10 minutes and it should be fixed! Try pausing and recording things again... hopefully you've just saved yourself £65
If you've not been so lucky, you'll have to get Sky to fix it for you. Some people report that if you ask to cancel your subscription Sky sometimes offer a free callout to fix the problem - you're more valuable to them as a paying customer than the cost of an engineer callout
Sky customer service's (seemingly unpublished) freephone number. You need to dial 0800 731 6965, then option 2, option 4 March 9, Sky have closed this Freephone number
HARDWARE RESET
Copied from http://www.digitalspy.co.uk/forums/showthread.php?t=484098
Full System Reset via front panel:
  1. Remove power at mains.
  2. Hold LEFT+RIGHT.
  3. Apply power, wait for ring to light.
  4. Release LEFT+RIGHT, press SELECT.
  5. Ring cycles backwards while disk is quick formatted.
  6. If format sucessful PLAY lights up, if not RECORD lights up.
  7. Box goes into standby - wait 30 seconds are wake it up.
Warning: Full System Reset deletes all your recordings and planner entries.
Top Nextar GPS Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Nextar GPS Expert? Answer questions, earn points and help others
