I DON'T KNOW. IT MAY BE DIFFERENT IN DIFFERENT LANGUAGES. IF NECESSARY, YOU COULD ASK GEORGE AT <https://in.linkedin.com/in/george-thattarukunnel-999aa114a> . IN YOUR LOCATION, YOU MAY FIND THE SURNAME IN THE LOCAL TELEPHONE BOOK AND THAT WOULD BE A LOCAL CALL TO ASK.
I would urgently get the transmission oil level checked as it may be low as indicated by fault light activating whilst being on a sharp incline where low level would be made worse on start up.
Also if the g/box fluid has not been changed - get it changed. Although this is a ''sealed for life box'' in reality there is no such thing and many Jaguar forums recommend fluid changes at 60k miles.
I have changed mine !
The fluid level is not easily checked as it needs to be done at a specific temperature and is indicated by a slight flow out from a level plug on the side of the g/box.
Hope this helps - good luck
bruce.this job is the same as for ANY CAR.the oil canister is between the engine and the firewall.the sumplug is on the bottom of the sump pan.(as normal)fill with 5/40 full synthetic oil(the best you can afford)VW RECOMMEND 10k/1 year oil changes for this engine.(and so you can impress your son the R stands for "regulator"(engine)...the 32 is obvious (3.2 litre.)
regards.geoff.(nice car,bye the way)
