SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
SOURCE: xantrex 458 freedom....has stopped charging house
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
SOURCE: I have a xantrex 2000 watt freedom 458 freedom
this isn't an answer but i would like to just clear the water a little. how old is the unit? you say it the inverter works when on shore power ( 110v A.C. wall plug or 220 ) but it will not charge the batteries while hooked up to shore power? are you trying to use a generator to run the inverter and charge the batteries? I just need to a little more so i can better understand you problem and help you better
Looking forward to hearing back from you.
M.Woodring
SOURCE: I have the Xantrex Freedom
Upgrade to one of the Freedom remotes, the 458 has different software, and features than the old Freedom 1500.
SOURCE: Is there a bench test for the Xantrex freedom 458
My experience has been thay there is no real "bench test" available to the general public. You can do some testing if you are familiar with how to read the color codes on resistors, and know how to test relays. There are two fuses inside, so you can check their continuity. Before going to this trouble though, get on line and download the Xantrex trouble shooting guide, bulletin No. 512-0084001-01 rev1. If that is ok, it'll be a trip to the dealer, where you'll learn that it costs about $400 to replace the board. I'm on my second one, in two years, so they aren't a long life article I'm afraid.Hope this is helpful for you.
