SOURCE: have a multip speed dremel 350
clean the slots that hold the brushes, sometimes they get cloged and the springs do not push the brushes all the way to the armeture.
SOURCE: Cordless Dremel variable speed stuck on maximum
Hi, There are several dealers in London who can help you solve your problem. The following link is has a list of those dealers with addresses and phone numbers:
http://www.dremeleurope.com/dremel/dealerlocator/index.cfm?lang=en-GB
Good Luck to you, this should Fixya!
SOURCE: Variable Speed Control is faulty
Unfortunatly Dremel who is owned by Bosch has discontinued that tool and parts are no longer available.
SOURCE: My Dremel tool has intermittent power.
You can go to any repair facility and buy a replacement cord making sure of the wire guage and conductor (2 or 3) what you can do is make a wiring diagram and remove the old cord and holding the cord about 10 inches from end pull one wire at a time and if there is a break it will pull out to confirm your suspicion. Let me know if you need any more help and if I have answered your request would you please rate this response accordingly and thank you.
SOURCE: How do I attach tools to my Dremel?
hello. You loosen the arbor at the base of the shaft closest to the tool. There is a tiny wrench in the kit that came with the dremel, or you can use a pair of pliers to loosen it. Joe
