OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear.
SOURCE: Samsung SyncMaster 510N LCD TFT Monitor
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
Samir
SOURCE: Samsung GH19LS LCD Monitor wont display computer signals
You should have received two cables with the monitor. One is for VGA and plugs into you video card or computer board . The second one is for DVI digidal video and if you have that cable it plugs into the square connector. Then if you look into your monitor manual or quick setup sheet it will tell you how to connect and set the monitor to either VGA or Digital. I'm sure that is what has to be set. Don't hook up both cables to the monitor and computer. Only use the one. Digital gives you a better picture if your computer has that function. Hope this is helpful. Bud
SOURCE: problem with brightness of monitors SyncMaster 710n
HelIo! right after computer inclusions on the monitor screen have a tablet with the message which disturbs to work. The message: brightness of the monitor of 100 %! A problem: how to clean from the screen this tablet so she prevents to read the information. I have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another? have not found adjustment in the menu of the monitor brightness. And what should be brightness: 100 % or another?Thanks and sorry about my bad english. Afzal.
monitor, osd lockout Posted in Fixes ' Comments (32)
This has most likely annoyed many of you at some point. You turn on your monitor one day and see a jeering message telling you something about an "OSD Lockout". It doesn't allow you to change any of your monitors settings, including the setting intended to turn off this message. While I've only seen this error on HP monitors I know that others have encountered it on other brands as well. The fixes I provide should work on those monitors too. (Note: OSD stands for On Screen Display.)
Fix One:
Plug in the monitor and power it up. Hold down the Power button until you get a message saying "OSD Unlocked". If the problem persists after OSD is unlocked then unplug the monitor from the wall, wait 20 seconds and try again.
Fix Two:
Turn on the monitor and hold down the Menu button for 10-20 seconds. This should unlock the OSD.
Fix Three:
Turn off the monitor, press down the Menu button and then turn on the monitor. Wait 10-20 seconds. This should unlock the OSD.
Fix Four:
The Menu button may be stuck in a pressed in position. To get it "unstuck" you'll usually need to open up the monitor. This could be tricky unless you know what you're doing. Unfortunately there are too many models of monitor for me to provide detailed instructions. If you have warranty this is where you want to contact the manufacturer.
If you know of any other fixes feel free to contact me. Good luck!
Having other problems with your computer? Simply scan your computer for free to identify problem areas.
Techbelkin please rate me
