When starting the engine a white smoke comes out from the exhaust
SOURCE: white smoke mercedes benz 2008 gl-class 320
Seek out another mechanic. White smoke from the exhaust is a symptom of coolant entering the combustion chamber. Most of the time this is caused by a blown head gasket. A loss of coolant with no apparent leak, a white foamy substance on the underside of the oil fill cap, oil level overfull, and air bubbles escaping from the radiator are other symptoms of a blown gasket or cracked head. Stop driving this vehicle until you have this diagnosed and repaired. A compression test will verify this. Serious engine damage will occur if you indeed have an internal leak so make sure one way or the other.
