Most likely you'll need a new motor, you can check the belt, to see if its attached around the big pulley. To access, you'll need to pop the front cover off the unit, it has two tabs you push in, on the front, where the top lid meets the front cover. Use a flat-head, be careful not to scratch your paint.
You can also, take off your back panel, on the control console, and remove the wiring diagram, you can diagnose this washer yourself, because the motor has a blinking light that will indicate to you, what is going on with your unit, it will tell the problem for you.
Please take a look at this website, about half-way down, as it could also be your lidswitch.
http://www.appliance-repair-it.com/GE-washer-repair.html
Thanks.
how do i remove top lid on ge washer s3700e1ww?
