Hi, You can download a user manual from Samsung here:
(scroll down)
YP T7X
SOURCE: SAMSUNG YP-U1
try a Reset from the player's menu. You'll find that it rebuilds it's database and your tracks will show up. - Press & hold the Menu button - scroll down to Settings - Select Default Set - Yes I hope it works for you as it i=did for me :-)
SOURCE: YP-P2 FIRMWARE PROBLEMS
I had the same problem!
But I found the fix for it after much searching.
First, download the latest firmware directly to your computer's desktop from the Samsung website: http://tinyurl.com/3j4su4
The file is a Zip one so : make sure you extract the 2 files to your desktop!
-Connect your P2 to your computer and go to My Computer.
-Double click the YP2 icon.
-Copy the 2 extracted files from your desktop into the open window. (Do not put them in an already existant folder).
-Unplug the connection from your computer and restart your player.
It will do an update and shut down. Restart it a second time and it will finish the second update.
- There you go, it should work no problem.
The firmware update from having your player connected to the Samsung Media Studio 5 for some reason doesn't work properly.
By doing in manually it works just fine.
The update link I provided is for a US based player.
Just go through the Samsung site to find an update for other contries if you need too and follow the same directions I give above to solve your issues.
Hope this helps!!!
SOURCE: I need help deleting recorded files or songs from Samsung YP-T10
plug it into your usb port on the computer.
go to 'start' 'my computer' click on the new drive it shows, which will be the mp3
open the mp3 player files, click on video , files, music, or whaterver it is you want to delete. The files will show........click on the one you want to delete and hit 'delete' on your keyboard......done.
