SOURCE: Krups GVX2-12 Electric Burr... Problem:
First, unlock and unscrew the upper burr carrier. Clean and check the upper burr by gently running your finger over the teeth in the cutting direction. It shoild feel moderately sharp. If it feels very blunt, look at the teeth under a good light. If you see a substantial "flat spot" at the top of the teeth, probably the burr set will need replacement.
For the bottom burr, clean carefully its teeth, and the entire area in which it is housed. Include the outlet orofice as well. You may find a lot of oily deposits within here, so just clean them off as best as possible.
When all is clean, insert the top burr holder back in place. Screw it down until both burrs touch, then back it off (say) 1/4 turn, and lock.
Put some beans in the top, and switch on. Adjust the top burr until the desired grind is obtained.
The ground coffee should feel like a coarse sand when close to the desired grind size.
SOURCE: I have a Krups GVX1 burr coffe grinder.
You will have to disassenble the grinder by removing the screws from the bottom of the grinder. You should be able to get to the thermal fuse once you gain access to the insides.
Well worth attempting the repair if you have the replacement thermal fuse needed and can handle a soldering iron to unsolder and soldering needed to remove and replace the failed part.
The thermal fuse isn't like a normal glass tube automotive fuse, but you should be able to get a replacement one from Radio Shack, if you can't get one from the manufacturer.
Hope this helps you get it fixed and best regards!
