Question about Xerox WorkCentre 7120/P Printer
Error 012-284 on workcenter 7425 - Xerox WorkCentre 7120/P Printer
Xerox 7435 error code 010-328 whtes the problem
it is the code for fuser heat control problem. Usually, the unit has its airflow restricted try moving the unit or cleaning it to see if the problem clears
Here is a list of all the error codes
WorkCentre 7425 style Fault Code List Part
Aug 02, 2016 | Xerox Workcentre 7435 Color Multifunction...
Error code 041-348 in xerox work centre 7425
The MD Board is failing and will need to be replaced, the part number is 960K38900.
http://www.iteminconline.com/960K38900_960K38900-960K38901-960K38902-Xerox-Workcentre-7425-MD-P.htm
May 30, 2015 | Xerox Office Equipment & Supplies
How do I solve wc 7435 error 010-338?
Hi
I found information about this error and some approaches to solving it here:
http://www.support.xerox.com/support/workcentre-7425-7428-7435/support/enus.html
and they can be tried in the order given. Hopefully either 1 or 2 or 3 on the list will work as they are non-cost options as opposed to number 4 which could be quite pricey.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 27, 2014 | Xerox WorkCentre 7425 7428 7435 Second...
041 348 ERROR CODE XEROX 7435
That error is due to a problem with the MD Board. The most likely cause is the MD Board and needs to be replaced, link below for part needed.
Jul 17, 2012 | Xerox Office Equipment & Supplies
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox PE 120i workcenter. Error says
you need to remove your paper tray.take your toner carriage out ,yurn the mc and assess
Nov 29, 2009 | Xerox PE120i Laser Printer
Xerox WorkCentre 7120/P Printer Logo
261 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
quennie732
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
