SOURCE: Sony SDM HS74P Screen Stays on for approx 15 seconds then shuts off but power light is still on?
PWI17LS285A, ACTUALLY THE CAPACITORS DOES NOT KEEP ENOUGH CHARGE TO KEEP THE LCD WORK...
so the big capicitor needs to replaced? 100µF 450V
SOURCE: My Sony SDM-HS74P display does not stay on.
I have the same issue and wrote the monitor off for now after checking all cables (and a different computer). The logic circuitry and panel are sill ok as I can see a faint image with proper lighting and close inspection, but no backlight makes it useless.
Since there are 4 lamps (CCFLs) on this model, the problem likely is not there but on the inverter circuitry driving them. This does not look easy to replace as this is part of a bigger board.
It looks like some could repair by changing a few (or even one) component on the board, but unless your are used to this (de-soldering and soldering back), you are kind of stuck.
I will attempt this if I have time as I hate junking 99.9% ok hardware. In your case since this is an old monitor you should just replace it if not technically (on the electronics side) apt.
