Sea-Doo US Seadoo sea doo cdi ignition computer module 96 xp, gtx, gsx 787cc engine Logo
piccola winkey Posted on Sep 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
96 seaboo will not go full speed in water, but full rpm out of water
paul
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Sea-Doo US Master 1,190 Answers
  • Posted on Jul 08, 2014
paul
Sea-Doo US Master
Level 3:
Renaissance:
Answers
1190
Questions
Helped
264115
Points
1883
Carbs need cleaning and check the pulse jet that squirts fuel on set off , fuel pump diaphrams ok ?
1helpful
What is the maximum speed peugeot 604 turbo diesel 1979
This unit has an output of 95 bhp (96 PS/71 kW) of power at 4150 rpm, and maximum torque of 206 N·m (152 lb·ft/21 kgm) at 2000 rpm. A 5 speed manual transmission transmits the power to the driven wheels. Quoted kerb weight is 1465 kg. Top stated speed is 165 km/h (103 mph).
1helpful
Campbell Hausfeld 2200 psi pressure washer doesn't build up pressure
2 possibilities. It is not getting enough water from the hose or your pressure regulator is bad. Does it sound like the engine is developing full RPM? Could be and engine problem if not coming up to full speed.
High cruising rpm
no year, no real help.
mike cruises at 90 mpy (Dallas new speed limit 85 on one road)
larry at 75
me 45. so>>>
but doing it backwards works way better
what is speed at 3000 RPM , a common speed.
answer in my 96 goes 59 mph. in 5th gear.
the rpm is a function of what tranny and tire size.
here are all listed
The G16 is no V8 it spins fast and last 300k miles. if serviced.
see this table for 3000 rpm speeds.
there are 5 speeds possible in top gear.
what transmission tell you which it is , there are 3 trans. and 2 engines. each are Unique.
http://www.fixkick.com/part-time-test.html#SPEED
chart one is stock. tires.
chart 2 is big tires.
the equation is there so you can do yours, from any RPM you want.
1helpful
Coaster idling high and high fuel consumption
Water temperature is low cost oil is certainly the easiest way is with a hard shell to block part of the warming effect of the radiator well as for how much you want to try to stop. Idle temperatures will rise up relatively low. What is the pull speed? Not run fast but continues to run uninterrupted some time. Usually two hours can be. Is to allow the engine to reach full swell purpose. Such a shift is to be based on the vehicle speed and the reference engine speed. Not based on the engine speed. Driving is probably the single 30 towards third gear, fourth gear towards forty, fifty five-speed ahead. Many people on the car ahead of change. As long as the engine sounds smooth, no trailer can be.
2answers
High rpm honda civic 96
-Possibly bend throttle cable. If not then back up the idle screw to normal RPM.
Mai
I would like to know if i can use the 92-96 speedometer of a gasoline 4x4 isuzu trooper, and put it on my 4x4 diesel bighorn 3.1, mine is not working properly, Rpm some time is dead, and the speed...
THAT SOUNDS MORE LIKE THE VARIABLE SPEED SENSOR! IT IS LOCATED ON THE TRANSMISSION! SOME OF THEM HAVE A SPEEDOMETER CABLE ATTACHED TO THEM, AND SOME DON'T! THEY WILL HAVE A 2 WIRE PLUG THAT IS ATTACHED TO THEM!
My RPM fall down
That is normal. When you put it in gear, the idle speed drops about 400 rpm.
2answers
Run hard at 2500 rpm 96 nissan pickup 2.4 5 speed
I had a similar problem mine would hit a rev limiter at 3500 rpms. it would blow black sut out of the tail pipe. Ended up being mass air flow sensor/valorem sensor. almost 500.00 from nissan. fixed it though.
Top Sea-Doo US Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Sea-Doo US Boating Expert? Answer questions, earn points and help others
