Frigidaire FAA065M7A Air Conditioner Logo
Posted on Sep 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Air conditioning diagram schematic system
Wiring to blower and thermostat
  • Official Brand Answer 4,342 Answers
  • Posted on Sep 10, 2013
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467079
Points
5907
Good Afternoon rguyton26, thank you for allowing me to assist you!
I understand you are seeking a wiring schematic on your Frigidaire air conditioner, FAA065M7A post above. I have located the Wiring Diagram, Owner's Guide and etc on the manufacturer website. I hope this information proves to be helpful. If you have any additional questions, please feel free to reconnect!
2answers
2007 Ford Edge SE manual. A/C Heater blower motor @ resistor wiring diagram.
Question edited for clarity. HVAC (high volume air conditioning) is only found in your home or office.
Question moved to model category.
https://www.google.com/search?q=2007+Ford+Edge+SE+Heater+blower+motor+resistor+wiring+diagram
My 2004 saturn air conditioning wont blow air unless u turn right how do I fix it
Test the electrical circuits for the blower motor . Look at a wiring diagram and find any connectors or ground connections an see if any are loose .Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size . Under system click on HVAC ,under subsystems click on HVAC controls . Then click on the search button . Watch this video
Blower Motor Problems Auto Repair Help
Heater Blower Motor Troubleshooting
How do you get the heater to work on a 2003 Chevy venture mini van
When you change the mode from floor to vent to defrost do you hear switching taking place behind the dash or inside ?
Air Delivery Improper
Test Description
The numbers below refer to the step numbers on the diagnostic table.
The measured voltage should be near the specified values for each mode position.
The HVAC control module is supplied by two ignition 3 voltage circuits. Test the ignition 3 voltage circuit that does not supply the blower motor switch.
Step
Action
Value
Yes
No
Schematic Reference: HVAC Schematics
Connector End View Reference: HVAC Connector End Views
DEFINITION: Air does not flow correctly from the air distribution outlets.
Did you perform the HVAC Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - HVAC Systems - Manual
Turn ON the ignition, with the engine OFF.
Place the blower motor switch in the OFF position.
Is the blower motor OFF?
YES - Go to Step 3
NO - Go to Blower Motor Always On
Place the blower motor switch in each speed position.
Does the blower motor operate at all?
YES - Go to Step 4
NO - Go to Blower Motor Inoperative
Does the blower motor operate in each speed position?
YES - Go to Step 5
NO - Go to Blower Motor Malfunction
5
Except for the blower motor speed, are all of the functions of the HVAC control module inoperative?
YES - Go to Step 14
NO - Go to Step 6
6
Place the blower motor switch in the maximum speed position.
Place the mode switch in the vent position.
Place the recirculation switches in the recirculation position and in the outside air position.
Does the recirculation door move to the correct position for each selection?
YES - Go to Step 7
NO - Go to Air Recirculation Malfunction
7
Place the mode switch in each position.
Is the air flow sufficient from the correct outlets in each mode?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 8
8
Inspect the air distribution system for the following conditions:
• A dirty HVAC air filter, if applicable
• An obstruction to the air flow
• Air leaks
• Misaligned air ducts
Did you find and correct the condition?
YES - Go to Step 23
NO - Go to Step 9
9
Inspect the mode door and the mode actuator for the following conditions:
• A misaligned mode actuator
Refer to Mode Actuator Replacement .
• Broken or binding linkages or mode door
• An obstruction that prevents the mode actuator from operating within its full range of motion
• Missing seals to the mode door
• Misaligned seals to the mode door
YES - Go to Step 23
NO - Go to Step 10
10
Turn OFF the ignition.
Disconnect the mode actuator.
Probe the ignition 3 voltage circuit of the mode actuator with a test lamp that is connected to a good ground.
Does the test lamp illuminate?
YES - Go to Step 11
NO - Go to Step 20
11
Test the ground circuit of the mode actuator for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 12
12
Measure the voltage from the mode door control circuit of the mode actuator to a good ground.
Place the mode switch in each mode position while observing the voltage.
Does the voltage measure near the specified values for each mode position?
Vent 0.2V, Bi-Level 3.0V, Floor 6.0V, Mix-Blend 9.0V, Defrost 12.0V
YES - Go to Step 18
NO - Go to Step 13
13
Test the mode door control circuit of the mode actuator for an open, high resistance, short to ground, or short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 19
14
Test the ignition 3 voltage circuit of the HVAC control module for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 15
15
Test the battery positive voltage circuit of the HVAC control module for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 16
16
Test the ground circuit of the HVAC control module for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 17
17
Test the off blower motor control circuit of the HVAC control module for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Go to Step 23
NO - Go to Step 19
18
Inspect for poor connections at the harness connector of the mode actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 21
19
Inspect for poor connections at the harness connector of the HVAC control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 23
Go to Step 22
20
Repair the ignition 3 voltage circuit of the mode actuator. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 23
21
Replace the mode actuator. Refer to Mode Actuator Replacement .
Did you complete the replacement?
Go to Step 23
22
Replace the HVAC Control module. Refer to HVAC Control Module Replacement .
Go to Step 23
23
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 8
2answers
A/c blower motor works if I pull power and plug back in until I cut engine off. Then I have to repeat process
Daryl, You may want to check the blower relay/ just switch with one of same type and try and if OK, problem could be the blower motor, wires/plug loose,damaged,burnt or a faulty blower motor resistor. Second link has some trouble shooting of a overheating wire problem, that is to be common in these trucks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY 2003 Silverado Blower Motor Resistor
Sparkys Answers Chevrolet Silverado Blower Does Not Work On Any Speed
03 Silverado heater fan problem ChevyTalk FREE Restoration and Repair Help...
1helpful
Thermo set "heat" and "Auto
Check the fan relay. These relays are used to cut the fan on and off when the thermostat is set in the air conditioning or heating mode or when you move the thermostat to the "Fan On" position. The low voltage usually the green thermostat wire is wired to terminal #1. The low voltage common wire to terminal #3. One line voltage wire is attached to terminal #4. The high speed blower wire usually black is attached to terminal #2. When the thermostat calls for air conditioning or "Fan On" the 24 volt coil is energized, the terminals 4 and 2 close. This causes the fan to come on in high speed. When your home cools down and the thermostat cuts the air conditioner off, the low voltage coil terminals 1 & 3 are denergized, and the fan goes off. Sometimes these little relays stick which causes the fan to run all the time or will not make good contact, which causes the fan to not run in the "Fan On" or air conditioning mode.
Wiring schematic
http://friedrich.com/downloads/Ductless_Service_Manual_MW18Y3F_MR18Y3F.pdf
go to this web site. The manual has a diagram that you are looking for.
Hope this helps
I need to know what each color means on my distributor???
Review this guide as reference; this Electrical Schematic Diagram applies for 1994 Accord Coupe series of model. Here you will find complete explanation about electrical system of the vehicle. Started from Troubleshooting (tips and precautions) on handling the electrical system, in this manual you will be guided step by step examining each electrical component installed and its connection for example in Wire Harness and Ground Location, started from Engine Compartment, wiring harness is shown from engine ground cable, starter cable, and battery ground cable.
These 359 pages of pdf.fieltype manual is divided into some sections which are Wire Color Code, Relay and Control Unit Location, Wire Harness and Ground Location, Air Conditioning System Circuit, Anti-lock Brake System, Battery, Blower Control, Charging System, Cruise Control, Fan Control, Fuel Pump, Fuses, Ground Distribution, Heater Control, Ignition System Control, Lighting System, and etc.
Download the complete 1994 Accord Coupe Electrical Schematic Diagram here.
You can also find complete workshop manual of 1994 Accord Coupe here.
Pass: freepdfmanual.com
Good luck.
Heat not blowing on heat cycle
Have to know what kind of heat it is, Gas, Electric or Electric Heat Pump.
Heat pumps, when air over air type, have an extra setting on the thermostat labeled Emergency Heat, Although these thermostats can work on the other types of heating as well.
Both modern Gas and electric furnaces have the blower controlled by a blower board. The flame and or heating elements can also be controlled by the same or a separate board. SO you could have a board problem, or a safety switch or other symptom causing a safety switch to trip off on you.
Consult with your diagram and find something you can recognize then trace the wires down and follow to where you get the power to turn on the heat (usually always R feeds thermostat and W feeds Heat). Colors of the attached wires means nothing at this point. Look for the terminal designations not colors.
Hope this helps you. Please grade me accordingly and GOOD LUCK. :)
1helpful
1995 Buick Lesabre- heater blower
Notes Electronic Automatic (RPO C68)/ Dual Zone Air Conditioning (RPO CJ2) 62396444
Top Frigidaire Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
