Ice builds up in the freezer
Hi, The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Take care
Hi Lynda Camara, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is it actually going in defrost mode and for how long. Indoor fans working when cooling? You will have to push in the door swithes to know.
