Toshiba Windows 7 satellite pro. screen goes randomly all light grey. can still use it (using now typing this) but can barely see the screen. two times this happened. first my friend solved it. second time like 3 weeks after it happened again. it just went. this is the third time it happened and it hasn't went back to normal yet :( is it the graphic's card? my laptop still has 351GB out of 448GB so that cant be the problem? please help. a free option would be great because I'm currently broke :( i only had this laptop for 10months and I'm not sure on a guarantee because I didn't buy it? HELP AS SOON AS POSSIBLE :(
SOURCE: Toshiba Satellite P105-S6084 Laptop Boot Problems.
This happens sometimes due to faulty memory or faulty software that causes errors in filesystem. You need to obtain a Windows XP with the correct edition that is installed and boot into it. Then go into Recovery Console and wait for the c: prompt asking which windows you want to log into. Select 1 for C: windows. Then it will ask you for the administrator password. Enter it or press enter if there is no password. Type chkdsk c: /r at the c:\windows prompt and leave to run. It will take about 15 -30 mins. When finished, type exit and press enter. Press ctrl+alt+del to restart computer.
If problem is fixed, computer should start up fine now.
If you still have the problem, let me know so we can try something else.
Thanks,
Lolita
SOURCE: Sound Card for Toshiba Satellite A135-S4656
Try the download from the link bellow. If this driver doesn't work, then you will need to get the exact Realtek sound card model you have and check Realtek and driverguide.com for the XP drivers.
SOURCE: Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
SOURCE: My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
SOURCE: After a while the screen goes grey and the computer wont respond.
it should be problem of graphics card or the graphics chip. if that is
from nvidia, setting up ntune may cause such problem or if you did any
overclocking. may also have a problem of getting hot. try reinstalling
operating system if you feel comfortable of reinstalling OS. it would
solve any driver related issue.
Then check the cooling system of your laptop.
finally think about a change if none works.
