SOURCE: HP OFFICEJET 7210 ALL-IN-ONE
Time for a new pca carriage. part number C8963-60051. good luck finding one though. All your problems are caused by a stupid little plastic tab that used to hold the metal thing in place. now, it moves around when you put in a cartridge and doesn't make contact with the right circuits. I really hate HP for making such a crappy part and then having no way to replace it. Well, besides sending it to them so they can charge you $215+ to fix it. That's more than what I paid for new!!!
SOURCE: Hinges for top cover for HP officejet 6210- Q5820A
Let me know if you find a source for replacements. In the mean time, I kept my unit working by just removing the broken top half of the hinge.
You have to remove 5 screws using a TORX T10 screwdriver. First remove the small plate covering the back of hinge on the outside. Then remove the two vertical screws at the top of the hinge up under the hinge lip. Then open the cover (be careful to hold it in place so as not to damage the three flex connections between the lid and body) and remove the other two screws at the top of the hinge. Remove the broken top half of the hinge and lower the cover back down. Until you find a replacement hinge, you can put a piece of heavy duty tape on the back where the hinge was.
SOURCE: left hinge is broken on HP officejet 6210
SOURCE: Can I get parts to replace broken hinge?
SOURCE: left and righ hinge is broken on my HP officejet
I "inherited" a 6210xi because BOTH hinges were broken... poor and weak plastic design that breaks if the operator tries to raise the access past about 40 degrees for access to ink cartridges... of course after the hinges break it doesn't close properly to start again (except with creative taping!). In my pursuit of these parts I found that the lower hinge part (broken) Part#JB6100289A is actually a Samsung part for their SCX-15 printer/scanner. It was also interesting to find several of these 6210xi's for sale on eBay and other places for $10 or less as "broken, parts only" and AMAZINGLY, it was the same broken hinge part that put all of these out of service. Found the HP Part number as RG5-6317-0000N but couldn't find anything except to buy either the Top half of a whole 6210 or the Bottom half for hundreds of $$'s, far more than the WHOLE new working item would be. UED.net listed the part as "non-stocking" at $2.27 each, available Aug 8, 08, but it turned out to be that they are negotiating for access to that parts and VIOLA! a few months later I received SIX hinges at $2.27 each plus shipping. You have to be creative to keep your old stuff working.
