Automatic Activation of GPRS/MMS/WAP
Go to Menu -> Services -> WAP -> Settings -> Edit Profile
Select Sun WAP, Press Activate Profile and Save
Go to Menu -> Messages -> MMS -> Message Settings -> Server Profile
Select Sun MMS, Select Activate Profile and Save
For corporate accounts, fax a letter of request and ID of the authorized signatory to 395-0138. Approval and activation maybe slightly delayed.
Text "ACTIVATE" and send to 2300
If unable to activate,please call Sun Customer Hotline (200 on your mobile phone).
* If surfing or MMS sending does not work or results in an error, please proceed to the next step for manual setting.
Manual Activation of GPRS/MMS/WAP
Setup/Enable GPRS
Go to Menu -> Services -> Data Account -> GPRS
Select Sun GPRS
Account Name: "Sun GPRS"
APN: "wap"
Select SUN MMS
Account Name: "Sun MMS"
APN: "mms"
Exit and save settings
Setup/Enable MMS
Go to Menu -> Messages -> MMS -> Message Setting -> Server Profile
Select Sun MMS, Select Edit Profile
Rename Profile: "Sun MMS"
Homepage: "'http://www.mmscenter.suncellular.com.ph"
Data Account: "Sun MMS"
Connection Type: "HTTP"
Proxy Address: "202.138.159.078"
Proxy Port: "8080"
Select Activate Profile, Yes to activate profile
Setup/Enable WAP
Go to Menu -> Services -> Wap -> Settings -> Edit Profile
Select "Sun WAP", Select "Edit Profile"
Rename Profile: "Sun WAP"
Homepage: "http://www.suncellular.com.ph"
Data Account: "Sun GPRS"
Connection Type: Select "HTTP"
Proxy Port: "8080"
Setup/Enable GPRS
Select Sun GPRS
APN: "wap"
Select SUN MMS
APN: "mms"
Setup/Enable MMS
Proxy Port: "8080"
Setup/Enable WAP
Proxy Port: "8080"
YakYak, Go onto your network providers website register on there, and there should be a option once you have signed up, confirmed your email address etc... You should Be able to set it up for MMS & GPRS, hope this works and good luck.
Ben
when i go to send a mms it tells me i have know mms service record
