Noisy motor indicates bearings on the shaft are going bad. This happens when you have a shaft seal leak and the leaking water is getting to the bearings. Sounds like you need to replace shaft seal and set of shaft bearings. Easy fix is to replace the motor only for about $150.00 for motor replacement. Around $40.00 for seal and bearings and some of your time.
You have to completely disassemble the pump and motor to replace a seal and the bearing(s). It is better to take it to a local electric motor repair shop if you are not sure how to complete these repairs. We charge about $60 total for the job and guarantee it a year. Most shops should be about the same.
MOTOR SHOULD HAVE A RESET BUTTON. IF U CAN FIND IT, HOLD IT IN-IF MOTOR RUNS RESET MAY HAVE TO BE REPLACED.MAKE SURE MOTOR DOES NOT OVERHEAT UNDER LOAD-THIS MIGHT BE THE PROBLEM.
