Kid Riffic Toys Kidriffic Jump Smart Logo
Posted on Apr 14, 2009
Frayed elastic cord
The red elastic cord has frayed and is ready to break. Where can I get a replacement cord?
  • sschisl Apr 15, 2009
    the elasic cord on our jump start trampoline broke - we'd like to replace it - anyone know where we can get one?
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jun 12, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3889
Points
21
Call 800-872-6765, or www.1800trampoline.com
click on the trampoline and at the bottom of the description it says click here to order parts.
Why does my thread keep breaking on my brother ce4000?
Change the thread in the bobbin and then try...then change the top thread only and try...helps to see where the problem could be...change the needle again and get it from a different pack. Sometimes needles from the same pack can have the same problem( burrs, nicks, filings, etc...) that are impossible to see with the ***** eye. Oh and buy brand new thread...we tend to think that all thread is good to use and it is NOT. Old thread looses elasticity, frays, and breaks constantly. It may 'look' good, but is a sewists greatest enemy!! Good luck!
Riccar vacuum 8625 vacuums the floors;but does not seem to have suction for the carpets
The belt may look fine but could have lost elasticity. Stretch belts will lose elasticity and should be replaced at least once or twice per year. If the brush strips are worn or frayed it will not pick up properly.
HOW CAN I REPLACE THE ELASTIC CORDS,ON MY SHOOTING STICKS?
Rafael, I am not aware of any camera repair station that will do this...., but as these tripods use the same type of bungee materials as tent poles..., I would contact a company in your area that does repairs on backpacking tents. I suspect that they can probably fix this for you.
Was useing kango breaking concrete and it stopped working
Check:
  • frayed wires where it enters Kango
  • is power at switch
  • Power thru the switch
  • Frayed wires at cord plug
  • And finally - Brushes
These are the EASY checks, if none of the above, take it to your local service center.
Good Luck
Nov 09, 2013 • Hammering
When I plugged iron in sparks came out at wall and iron where the cord connects.
If you've had this iron for a while it sounds like the cord may be frayed.
switch it off at the wall and unplug it, check the cord for wear, if the insulation is frayed, torn or broken and there are black burn marks on the cord where you saw sparks then the cord needs to be replaced.
DONT plug the iron back in until the cord is replaced.
Otherwise If there are no breaks or black burn marks on the cord, then your power point may be faulty and needs to be replaced!
I hope this was helpful
MobileJB
1helpful
Where to buy frayed elastic cord
http://www.1800trampoline.com/jumpsmarttrampolinebungee.aspx
42helpful
4answers
Trampoline bungee broke and I need to buy a replacement.
Hi ajrother...
Amazon provides many products, so take a look there. This one can help you Upper Bounce Replacement Elastic Bungee Cords for Trampoline Jumping Mats... (If fits of course).
Also you can contact the seller if helps. Hope this was helpful. enjoy
2helpful
2answers
Thread frays and breaks when sewing and embroidering.
Make sure that the machine is threaded correctly, that the needle is in properly, that the bobbin case and bobbin are both inserted correctly and that you are not using old thread.
Make sure that there is a new needle in the machine and loosen the top tension about a number
You need to carefully re-thread the machine.
Power cord
May need to break the unit down to replace the cord,there should be some tec screws under the belt cover to remove the motor housing cover, may be two to thee wires. the rest should be simple.
Top Kid Riffic Toys Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Kid Riffic Toys Toy Expert? Answer questions, earn points and help others
