SOURCE: Whirlpool Inglis IP44002 Top Loading Washer
What I tried was pushing the lid down and I could hear the machine trying to kick into a spin so then while pressing the lid down i rotated to cycle knob slightly ahead and the spinning started. So I geuss I need to fix the connection between the lid and the machine?!
SOURCE: Fron t Load washer will not unlock
Here is the web link service manaul for your washer below. Go to troubleshooting guide. You can drain and unlock your door by using the test mode in the service manual.
http://136.166.4.200/contents/Laundry/WM2042/WM2042xx_Service_Manual.pdf
SOURCE: Whirlpool Inglis washer super capacity, 8 cycles,
I received an Inglis Washing machine from soneone on freecycle. They thought the belt had broken, doesn't have a belt, it's gear driven. I'd bet the noise you hear is the coupling going out, (rubber). Good luck.
SOURCE: The door on my washer won't lock!
the door lock has internal relays, if they go bad, the motor control board will not function. Even if you cant physically see anything, and even if the door still locks, the door lock assembly is still the most likely problem and needs replaced. The only way to test it is with a multimeter to know for sure before you buy a new one
SOURCE: GE front load washer, wbvh5200j1ww. no power.
the door can be manually unlocked by removing the bottom front panel, reach up and there is a pull tab on the lock mechanism. it is a crime that they do not post this online or in the manual, and let folks ruin their clothes.
power problem was a part called the "FILTER" it is where there power cord plugs into, something along the lines of part number 201. cost is $85 plus tax. service man has not seen one of these ever go before.
