Guardian Rv Generator 4800 Watt, Gasoline, Primepact 50G Logo
Anonymous Posted on Apr 14, 2009
Guardian primepact 50g rv gen starts for 2 sec then shuts down
I have a replacement guardian primpact 50g rv gen. that starts for 2 sec then shuts off. The old one that I replaced did the same after 4k hours. That why I bought a new one. We have replaced the fuel disconected the remote to no avail. one of the reason to install a new one was a electrical ordor coming from gen area so we thought gen was out of life. Any suggestion on how to isolate problem.We have 2 relays not replaced yet that supose to disconet hooked up power to rv when the gen is running.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
627
Points
This story ends with bad gas and silicone in the gen tank
I have a Guardian RV 3600 watt generator than wont run more than a few seconds. I have to hold my hand over the breather to get it to fire then as soon as it revs up it shuts off.
carburetor restricted due to long time storage drop carb fuel bowl unscrew the jet and pull down the fuel tube clean them and your generator should run much much better
Charger not charging and motor runs fine
You need to check the rectifier first to make sure it has AC power on the 2 x AC terminals and 13.8V DC on the DC side, if you have AC and no DC replace the rectifier, if you have no AC check the stator windings
Where is the starter on a primepact 50g
follow red thick wire on right side of the solenoid the starter is on right side rear hidden by the air box that surrounds the gen.
I have a new Guardian 40G generator that won't start (correctly, anyway). When I squirt gas into the intake it runs until that is gone then dies. The fuel pump is pumping gas to the carb. but it seems to...
Try to measure the voltage at the connector when trying to start.
If it is 12 V and the engine does not start - disconnect it and try again.
Have in mind that you must have protections (Shut down):
  1. Low oil level;
  2. Low oil pressure;
  3. High temperature.
and this valve may be responsible for them.
Each time I run the microwave all power shuts off until it resets itself
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
2answers
RPM/voltage fluctuation on Guardian Primepact 50G
go to www.zabatt.com - look in their Service manuals section - good luck!!
2008 Gaurdian Generac 3cyl diesel shuts off after hitting bump
If you dont find a solution here. Call Generac in Waukesha WI. and get the number for Robert Schwalm Co. He is the best in the Country for Generac I used to be #2 but I havent worked on all the new Generacs. Give me an old RV unit and no one is faster!
Guardian rv generator
Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
I have a 7500 watt guardian rv generator and it is difficult to start if not used on very regular basis. It cranks but will not fire. If I go out and manually fool with the choke it starts. Obviously it is...
Before starting the genset remove the air filter and check the throttle plate on the carberator, it should be closed. If it is opened, then you choke coil is worn out and needs to be replaced.
Have a 16k propane guardian generator have to manually start and
Is this an RV generator?
If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
Rate me,
Carl
Top Guardian Electrical Supplies Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
CJ Rock
CJ Rock
Are you a Guardian Electrical Supply Expert? Answer questions, earn points and help others
