Your router is out of support, so it won't be easy to upgrade the firmware.
You should log into the router. With its IP address (192.168.1.1) and standard ID (admin) and password (admin). You get there by opening a browser and typing the ip address in the adress URL line. Please check back to me after you succeeded to get this far. Fred
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
