Question about Pool & Spa
Garden leisure spa
My garden leisure spa stopped heating completely...we changed the heating element and it worked fine for a few days, now it is not heating again...maintains a low heat
    New Friend:
    Problem Solver:
  • 5 Answers
Check to make sure you are getting 220 to it if not the check breacker
Posted on Nov 09, 2013
SOURCE:
What size Electrical breaker do I need for a 525L Garden Leisure Spa?
check inside power box cover for voltage requirements
Dec 20, 2017 | Leisure Pool & Spa
Leisure Bay -My spa will not heat - no FLC/FLO code/Voltage is correct/4KW Dry Element Heater test 15.9 Ohm across leads and OL on each to housing
It appears per your test that the heater May not be the problem as it shows that it may be good.
Your error message is a Flow condition / Restriction
Try cleaning the filter
Nov 09, 2014 | Pool & Spa
My Therapure four person inflatable suddenly stopped working. electrician says outlet and breaker are fine. I can get the plug to blink red but then it throws my breaker. no luck with 1 800 #
It is more than likely your heating element. Not sure what style they use but if you send me a pic of your equipment, spa pack w/ the cover removed, I can walk you thru how to test it.
If you have a good grasp of electricity, find the heating element and with the power off remove the leads. Try to plug it back in, reset the gfci, and give it a minute. If it doens't trip and everything runs fine replace the heating element. With most spa packs it is possible to replace only the element, some like watkins you have to replace the whole heater. If the spa still trips with the heater disconnected start unplugging your equipment starting with the ozone, then blower, then pumps, one at a time until your braker stays on.
Oct 18, 2013 | Therapure Four Person Inflatable Round Hot...
Leisure Bay spa will not heat past 86 degrees. Element and sensors are new. Spa has excellent flow and correct voltage at terminals.
if the spa does not heat up to 104 degrees then the temp sensor is what you are going to need.
Are there error codes showing on the screen of the topside?
You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
Replaced heater failed within 2 months
If your filter is plugged causes the heater to work harder(overheat). Rus
Mar 17, 2010 | Heating & Cooling
Pool & Spa Logo
258 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
