Question about Korg PA3X61 61 Key Workstation with Touch Display Regular 886830349317
Hello, I own a korg pa3x keyboard and I have a set of styles that are completely locked and I can't do any editing. The conventional ways of unlocking styles through the keyboard (for example through "Media" menu .. etc) did not work. It seems they're coded or something .. any suggested way or suggested contact (for a price) who can unlock them ? Thank you
4 Suggested Answers
SOURCE:
wayneard
  • 1901 Answers
SOURCE: Looking for a used ROLAND or KORG keyboard, 7-Octave
This is not a site that sells products. We are a free technical support site.
I might suggest www.ebay.com or www.craigslist.com for a keyboard.
Thanks for using Fixya just the same.
Good luck.
Wayne
Posted on Nov 03, 2009
  • 1140 Answers
SOURCE: hi i im trying to
Your answer is here:http://www.korgpa.com/pa_root/en/products/pa800_soft.html Look under Utilities.
Posted on Oct 13, 2010
  • 5603 Answers
SOURCE: Hi Iam using my
The styles on the PSR9000 are NOT available on the PA50. Any styles of the PSR9000 would only come from the audio generation and outputs of the PSR9000. The PSR9000 would have to be setup to the style independently as that cannot be controlled via MIDI from the PA50 controls.
Posted on Jun 25, 2011
My synth wont load when I power it on. can anyone help?
I suggest a hard reboot / initialize. Istructions are in your manual or on the Korg website
Jun 09, 2015 | Korg Pa800 Synthesizer
How to reset pa 50
The manual should the factory re-initialization procedure. If not contact Korg customer support
Dec 10, 2014 | Korg Pa50 Professional Arranger Keyboard...
Can somebody post the PA800 Diagnostic Menu Command
The details are highly confidential and have only ever been released to engineers under Non Disclosure Agreements, who work closely with Korg in the design process. If anyone tries to tell people about it on the forum then a breach of an NDA has occurred and whoever did it could be sued by Korg. The person posting those details could have their account on the forum suspended.
Please understand that there are very good reasons why Korg want to keep those details confidential. The functions were designed for use in the factory when the keyboards are manufactured. Two of the functions can completely wipe the internal SSD and the boot EPROM rendering the complete keyboard unusable. One of the circuit boards would have to be returned to a factory for the chips to be re-initialized using specialist hardware plugged directly into the CPU board. The necessary hardware to re-initialize the SSD and Boot EPROM is not even available to Korg service centers.
If you are someone who has discovered the way to access the system diagnostic menus, then there is a high risk you will completely trash your Pa2x/ Pa800 etc, turning it into a "brick" that will no longer be capable of reloading the OS or factory data. Korg representatives have said to us several times that damage caused in this way is NOT covered by warranty. If two of the functions in the system diagnostics menus are used, then to get the keyboard working again, service centers will have to replace the complete "main board". This is the board which contains the SSD and boot ROM chips. You are looking at a repair cost of over $800 plus shipping.
Oct 24, 2014 | Korg Pa800 Synthesizer
How can I factory reset my korg i3 ?
Initialization: Hold Edit/Style and Arrange/Play while turning it on.
Preload: Disk Load (IFD01P for i3 and i2, IFD02P for i1)
ROM Check: Hold Enter and 7 while turning it on.
Sep 06, 2014 | Korg Music
Korg pa 800 gone dark
Sounds like your keyboard screen is going bad, You need to contact Korg and order one, you can do it yourself or they have authorized repair shop around your house.
Good luck
Jun 10, 2014 | Korg Pa800 Synthesizer
Korg pa800 256mb styles set
I wouldn't recommend doing that, because your OS system could freeze occasionally
Jan 29, 2014 | Korg PA800 61 key Arranger Keyboard Kit
Korg m50 freezes after 10minutes
Hello I have this M50 61 key korg model, I had the same issue the fix is simple remove the back cover on the unit, carefully push in all the small cables reattach them well do it to all the small connectors these cables get lose and cause this issue, good luck let me know if that helped I fixed mines that way its been working excellent since. good luck..
Jun 08, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Hi Iam using my korg pa50 as the master keyboard ive connected the midi cables to my other keyboard which is a yamaha psr9000 I cannot play the chords on the pa50 using the styles on the psr9000 is there...
Jun 25, 2011 | Korg Pa50 Professional Arranger Keyboard...
How to save styles in user pa800..
When you are in style play screen , press record , then select record/edit , it leads you to record screen. on record screen touch upper right hand of the screen (page menu) and select "write style" and this way you can save it whereever you choose. once you are done , on same page menu choose "exit from menu" to get out
Jan 19, 2010 | Korg Pa800 Synthesizer
Korg PA3X61 61 Key Workstation with Touch Display Regular 886830349317 Logo
109 people viewed this question
Top Korg Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Korg Audio Player and Recorder Expert? Answer questions, earn points and help others
