Can anyone tell me how to clear the V-chip channel lock on a JVC AV20220 TV? I do not have the orig. remote, have tried a couple of universals but have not been able to get one to operate the tv. Wondering if it's because the channel lock is on why the universal won't work? Using front panel button menu, it will autoprogram and can see the channels flashing on as it passes them, but at the end goes to channel 2 and won't go anywhere else.
Press the
"Menu" button to set the lock code for your JVC TV. A padlock icon
will appear on the menu display.
Press "Zero"
to access the lock code function then use the left and right arrows to select
the four-digit number for your code. Use the up and down arrows to move to the
next area of the display.
Select the up or down
arrow to finish your lock code then use the left or right arrow to save your
lock code settings and exit the menu. You can return to this display if you
forget your four-digit lock code and set another code.
Write your four-digit
lock code down and keep it in a safe, private area.
Select the locked TV
channel you desire to watch or want to unlock. A message will appear on the
display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by
entering your lock code on the 10-key pad. The message "Invalid Lock
Code!" will appear on the screen if you enter the wrong lock code.
OR
Select "TV"
from the menu then select "V-Chip" from the drop-down list on the
screen. "Please Input Password" will appear on the screen.
Enter your four-digit
password by selecting numbers on the 10-pad that appears on the V-Chip menu
display or your remote control. Create a new password if you forget it by
unplugging your TV power cord from the outlet then reconnect the power cord.
This procedure resets your password to "0000." Enter four numbers for
your new password using the keypad on the screen or your remote and select the
arrow to advance to the next number. Press "OK" on your remote or
select "OK" on the screen to set your new password.
Unlock a TV rating or TV
channel by selecting "MPAA" or "TVPG" from the V-Chip menu.
Use the up or down arrows to select the locked rating then select
"OK" on the display or press the "OK" button on your remote
control to unlock it. The MPAA represents the U.S. Motion Picture Association
of America rating system, such as "NC-17," meaning not intended for
viewers 17 years or younger.
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
[2]
Select "TV" from the menu then select "V-Chip" from the drop-down list on the screen. "Please Input Password" will appear on the screen.
Enter your four-digit password by selecting numbers on the 10-pad that appears on the V-Chip menu display or your remote control. Create a new password if you forget it by unplugging your TV power cord from the outlet then reconnect the power cord. This procedure resets your password to "0000." Enter four numbers for your new password using the keypad on the screen or your remote and select the arrow to advance to the next number. Press "OK" on your remote or select "OK" on the screen to set your new password.
Unlock a TV rating or TV channel by selecting "MPAA" or "TVPG" from the V-Chip menu. Use the up or down arrows to select the locked rating then select "OK" on the display or press the "OK" button on your remote control to unlock it. The MPAA represents the U.S. Motion Picture Association of America rating system, such as "NC-17," meaning not intended for viewers 17 years or younger. TVPG provides you
thank you, can you tell me the steps im in washington and im trying to help my mom in texas..she has a universal remote and not sure what buttons to push... anything will help
Well what was the answer because my TV won't program any channels when I auto scan it goes to channel 2 and nothing else
It's not a smart tv but it is a Jvc FLAT screen model #LT-40A-320LCD TV.ANDI HAVE IT HOOKED UP TO OUTSIDE ANTENNA AND IT SAYS SINGLE LOW AND WON'T PROGRAM ANY CHANNELS JUST GOES STRAIGHT TO CHANNEL 2. SAME ANTENNA IS WORKING ON MY OTHER TV.
