The error message of "PE" comes on the screen when I try to run a cycle. If I open and close the door and try it a couple of times the error message finally goes away and you can start the cycle. Occasionally the cycle would stop with the "PE" error again in the middle of the cycle and you would have to start all again. There is no troubleshooting guide for "PE", there is "IE" "OE" etc so not sure what "PE" stands for?? What can I do so that the machine operates as it should without having to fluff around?
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
I think you have the same problem as me. If you close the door HARD or give it a good bang - problem goes away? http://www.yellow-mini.co.za/dishwasherfromhell Cr@p board.
Hi
Error
code IE on LG dishwasher means Inlet error. This error comes up when the Water
Supply Tap is closed or Water Supply is shut off. If water supply is turned on
then make sure that the Inlet Hose is not kinked and water Pressure is not low
(should be above 10 psi). Next thing to check for is Water Inlet Valve, measure
the electric resistance of Inlet Valve. (950-1300 ohms) Make sure the filter of
Inlet Valve is not clogged.
Hope this helps... Please post back
for further assistance.
Daniel
Dishwasher flashes pe and won't run
DISHWASHER FLASHES PE AND WILL NOT RUN
PE flashes and won't start.
