Try setting back to factory default Power off tv Unplug power cord to wall wait approx 10 minutes Plug cord back in power on tv main menu will appear follow on on-screen instructions to reprogram.
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dear RyanVa21; Try changing the picture size with your set's remote, press the aspect ratio button. The remote must be the original Panasonic remote. Please let me know if that did it.
It's hard to say without seeing a picture. Panasonic has a site with pictures of various Plasma symptoms and the board that will cause that problem. Go to:
http://www.pasctraining.panasonic.com/PASS/elearn/PDP.htm
Click on:
Pictures of plasma symptoms
It will direct you to a PDF file.
It may not be your exact problem, but, it will show you which board will cause your problem.
Hope this helps.
explain vista tv is it for windows vista?
