For PUK codes, you can attempt 10x to enter the PUK codes in your phone. Once you enter incorrect PUK codes 10x,you'll recieve PUK blocked then what you need is to enter the PUK2. Make sure that you will enter the PUK2 correctly because if you enter incorrect PUK codes 10x,you'll recieve PUK BLOCKED error again. This time,you need to ask your service provider for SIM replacement.
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin no From Office Enter The Puk code and Yes So Puk code Open and Problem wil solved
Network code or PUK code usually is a 10 digit code which can be found on the sim pack with which your sim is bought. This code is usually placed under the PIN code. In a situation whereby you don't have the pack again simply call your service provider service center after acertaining you own the sim they will furnish you with the code. Hope this solution has been helpful?
You need to contact your network service provider for the PUK code (e.g.
if your SIM card was issued by Orange you would need to contact Orange
for the PUK)
You can only obtain the PUK code through your network service provider (e.g. if your SIM card was issued by Orange, you would need to contact Orange to get the PUK code).
The PUK code can be onbtained only from the network service provider (e.g. if the SIM card was issued by Orange you would need to contact Orange for the PUK code). Once you have your PUK code you enter it and the phone will prompt you to set a new PIN.
The Puk number depends on the pin lock on the sim, the phone will still work with a different Sim card.
To unlock the Puk code you need to call the contact number for the service provider for your Sim. Alternatively you can unlock the PUK code at a local shop for a small fee, £10 or £20 in UK.
To unlock PUK, call the company that branded your Sim card.
If you are in UK, contact is below, otherwise use google to find contact number in your area.
You should have a PUK number, on the plastic card where your sim card was.
Only your network service provider can give you that, if you lost the original.
