SOURCE: rolex watch yacht master set time
Let me start by saying that I own this watch and LOVE it!
To set the time you need to pull the crown all the way out to the furthest position.
To set the date you need to have the crown in the position in between the "winding" position and the "time set" position. Basically, pull the crown out till you hear/feel 1 click to wind, 2 clicks (total) to set the date, and 3 (total) clicks to set the time. I always set the date first to 1 day behind the current date. I then move the crown out to set the time so that I can set the watch to either AM/PM depending on the actual time. For example, I set my Rolex today (the 5th of January at 3pm - just an example). I would first move the crown to the date setting function and move it to January 4. I would then move it out one more position to set the time. I would go around the watch until the date changed to the 5th and then go around from 12 to 12 to change from AM to PM. I would then move it to the 3 and then I'm all set. This is helpful because it will ensure that your date will correctly change when the day changes and not be 12 hours behind.
SOURCE: bought rolex yacht masater 18k white gold on ebay
Bogus: No such Rolex factory model. At best is Franken watch.
Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
Hope this helps. Jewel
