I have the master vol. at nearly zero to keep things at a reasonable volume. Otherwise, even when my desktop vol control is all the way down, it's way too loud.
Go to your bottom right task tray. Right mouse click on the speaker icon, select open volume mixer. You should be able to adjust to your preference from there. Hope this helps.
It may be the control itself too. In time, these controls can get dust build up inside it. There are volume control spray cleaners available from Radio Shack or other electronic parts stores. The cheat on cleaning the control is to just rotate it from stop to stop as many times as it takes to clear the noise.
Yellow should be the positive. Try plugging in and reversing. The louder of the two is the one in phase and the correct wiring. If the speaker is pushing out when playing , it is in phase and correct also. The distortion problem could be a speaker going out. It may not be totally blown, but may be verging. Holding your hand out as wide as you can push against the speaker lightly. If there is a rubbing or scratching sound, the speaker could be damaged.If it moves freely, and there is no scratching its okay. Another possibility is the clean channel may have a channel volume set to high. Make sure the clean channel volume is set lower than the master volume otherwise you can get distortion on that channel too. Good Luck.
Two possible causes.1) Vol Settings changed in windows2) Bad hardware
1) Check your system's sound settings:
For Xp
Goto Control Panel
Double Click Sound and Audio devices / Sound, Speech, and Audio Devices
In device Volume Click Advance
Master Volume Control Window will open
Increase all the volumes to max, also make sure that Mute us UNCHECKED.
OR
From the bottom right corner of your screen in system tray, double click a small speaker icon and open Master Volume Control.
For Vista and Windows 7
From system tray (its at bottom right corner of your screen) double click on small speaker icon, it will open Volume mixer
Increase the volume to max.
2) If this does not work, then test your speakers by connecting it to some other system and vice versa.
If you get desired sound volume when you connect some other speakers to your system, then you have to change your speakers. And if your speakers are working fine on other system then you may have to purchase a new sound card.
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
I have nver come accross a setting that will lock the volume to a set level before, but here are a couple of possibilities that you may want to investigate for the cause.
Not all programs use the master volume control, so do, but most adjust the sound by the wav output. Put the mixer onto the desktop, open things like winamp, media player etc and adjust the volume controls on those to see what is doing what.
If you have a multimedia keyboard with a volume control on it, make sure when your typing it's not adjusting the volume at the same time. Again, put the mixer on the desktop out of the way and type as you would normally. It could even be just the vibrations from typing setting it off.
