Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
Turns on. Won't move. Lights stay on but speed lights won't come on at all. None of the buttons will respond.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Please contact the dealer and have a tech come with a programer and rread the error codes and tell u what is wrong and what to do or what needs to be done
Posted on Jan 20, 2014
SOURCE:
Clicks but won t turn over
Most likely a bad or low battery or bad connection or bad solenoid or starter or combination of any of them. Those lights will mostly stay on till the engine cranks before going off.
Jan 28, 2014 | Hyundai Sonata Cars & Trucks
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Sklz sport radar won't turn on
You have to move your finger around a bit while pushing to find the actual spot that turns it on... hold your finger down until it lights up ... the lights will spell, "Hi"
Mar 11, 2013 | SKLZ Sport Radar - Multi-Sport Speed
Toyota 4 Runner park lights won't turn off
faulty connection ,or check all your fuses from box,check fog lights fuse 1st,
Oct 29, 2012 | Toyota Cars & Trucks
My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
Aug 31, 2012 | Proform Exercise & Fitness
My samsung LED TV turns on sometines and other times the red light stays on and won't respond to remote control
leave the tv disconnected for a while because if you keep messing with it like my kids did and it will cause the bulb inside to burn out and will not even be worth fixing
Dec 13, 2011 | Televison & Video
My brake lights stay on until I begin to press the brakes my car. When I press the brakes on my car, the brake light won't turn on and won't turn back on. Does this mean I need to replace my brake...
on your brake pedal yuo have a switch to turn off the brake lights when not in use and when depressed turns on yuor brake lights. i would suggest either trying to adjust them on the pedal and if not replace the switch.
Sep 30, 2011 | 2006 Pontiac G6
Unit just quit. won't start up. press start button and won't even light up
please provide the model number of the Samsung dishwasher.
if none of the lights light up, then a fuse might be blown somewhere. If the problem is the start buttion does not start the dishwasher , then the door latch switch could be faulty.
Jun 23, 2011 | Samsung Dishwashers
Gear shift will not move from park
First thing to check is your brake lights. The brake interlock for the shifter relies on the switch that turns your brake lights on. If it's not working, you won't have brake lights OR the ability to move the shifter out of park. In an emergency, most of these vehicles have a small plug near the shifter that you can remove, push a button, and move the shifter without pushing the brake pedal.
Good luck.
Jun 04, 2011 | 2007 Dodge Caliber SXT Sport Hatchback
Rumbly groan with turns at low speeds esp just beginning to move car Dealer just repalced entire rack and pinion and sway bar. no noise first day- today heard noise again
My esp light, all wheel drive light, traction light and abs lights have come on & won't go off. Tried everything I could think of. Tires are new, brakes are a little over 2 years old. Recently tires rotated. Maintenance done regularly . Whats wrong?
Mar 26, 2010 | 2007 Chrysler Pacifica FWD New Cars
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
90 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
