RCA 25255RE2 - - Phone Logo
Laurel Bickford Posted on Sep 05, 2013
Voicemail messages i'm having trouble setting up messsage and checking v-mail
Marie Leible
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 07, 2018
Marie Leible
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
140
Points
If someone leaves me a message and I hit the play button it says no messages.
I have a VTech 6929 Phone system. I have tried everything in the manual instructions, but I cannot set up my mail box. I had it previously, and somehow it is gone. Can you help?
Question edited for clarity.
This phone system has two features.
Answerphone system which records messages to the unit.
and
Voice Mail System which is an extended (often paid) service from your telephone provider.
Sometimes a glitch at the Telcom will remove your Voice Mail. You will need to phone their customer service number and ask why they stopped the service you previously enjoyed? They will be able to put it back in place.
Page 32 refers
https://cdn-media.vtechphones.com/products/CS/CS6929/CS6929-X_WEBCIB_V3_20160224.pdf
Retrieve voicemail from telephone service Voicemail is a feature available from most telephone service providers. It may be included with your telephone service, or may be optional. Fees may apply.
Retrieve voicemail When you received a voicemail, the handset displays New voicemail and . To retrieve, you typically dial an access number provided by your telephone service provider, and then enter a security code. Contact your telephone service provider for instructions on how to configure the voicemail settings and listen to messages. NOTE After you have listened to all new voicemail messages, the indicators on the handset turn off automatically.
Set your voicemail number You can save your access number on each handset for easy access to your voicemail. After you saved the voicemail number, you can press and hold to retrieve voicemail. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Voicemail #, and then press SELECT. Use the dialing keys to enter the voicemail number (up to 30 digits). Press SELECT to save. You hear a confirmation tone. • 1. 2. 3. 4. 5. 33
Turn off the new voicemail indicators If you have retrieved your voicemail while away from home, and the handset still displays the new voicemail indicators, use this feature to turn off the indicators. NOTE This feature turns off the indicators only, it does not delete your voicemail messages. Press MENU when the handset is not in use. Press or to choose Settings, and then press SELECT. Press or to choose Clr voicemail, and then press SELECT. You hear a confirmation tone.
Set up voice mail
It's easy and you can follow below steps.
you can set up Voicemail and then record voicemail message by following these steps:
    1. Tap on Phone > Voicemail;
    2. Usually, you will be guided to automated voicemail system and you can simply follow voice prompt to set up Voicemail. If not, you have to follow these steps:
    a. Click "Set Up Now". You will be required to enter password. Tap password and then click "Done". Re-tap again and click "Done". Please keep in mind that password should be between 4-6 digits in length.
    b. Click "Custom" to record voicemail. Activate "Record" to start recording and tap "Stop" to finish recording voicemail. After you finish recording voicemail, tap on "Save".
how-to-record-a-voicemail-on-iphone-eotioun5s4qsaaff3yzmdxjb-2-0.jpg For more details, check: How to Record a Voicemail on iPhone
Setting an alternate greeting
THe 4406 works on a few systems? When you check voicemail, what does the voicemail speak to you? Example: "Welcome to Merlin Messaging" or "Welcome to IP office".
If Merlin MEsssaging:
http://avayaassistance.com/?p=1514
6helpful
THE ANSWERING SYSTEM WON'T RECORD MESSAGES,ALL MESSAGES GOES INTO POOVIDERS VOICE MAILE, AS IF MY PHONE IS BUSSEY?????? I CHECKED AND RECORD TIME IS NOT SET TO ANNOUNCE ONLY ANS ALL MESSAGES HAVE BEEN...
This happens when the number of rings to answer of the provider voicemail is less than the number of rings to answer that the answer machine is set for. For example: if your provider voicemail rings to answer is set for 3 rings and the answer machine is set for 4 rings then the voicemail answers before the 4th ring, therefore the answer machine will never get a message. I would call the service provider's customer service number and request they increase the rings to answer above the number of rings to answer that the answer machine is set for. If you don't want voicemail to answer any calls(when your line is busy or when the answer machine is turned off) ask your service provider to disable voicemail.
Lcd screen is blank also trying to pick up voice mail and can not
Called GE. Here's what's happening (at least with my phone). I use VONAGE as a carrier. VONAGE's package includes voicemail. I have my VONAGE voicemail account set up to take any call that comes in if the answering machine on my GE phone does not pick up -- for instance if I'm on the phone and I do not "flash" over to the incoming call, that caller will eventually be sent to my VONAGE voicemail where they can leave a message. (Otherwise I would either take the call, or, if not already in use, the GE phone/answering system1.gif would simpy take the message.) This GE phone is commucating with my VONAGE account and letting me know that I have a mesage in my VONAGE account voicemail. All I have to do is either go online and delete the messages (after listening to them of course) and refresh the page. Once the messsages are deleted, the carrier lets my phone know the messages are gone and the NEW VOICE MAIL prompt on the handset disappears. I suppose I can do it by listening to the messages by calling in and deleting through the touch pad on the phone as well
Messsage light remains on how do you turn light off if no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
3answers
Voicemail icon wont go away
Check your voicemail box and make sure you have listened to the messsage completely, if you hang up before you listened to the complete message it does not allow the phone to recognize that. After that reset the phone by powering it down and removing the battery and plugging it back in. That should do the trick.
2helpful
4answers
New Voice Mail
I have FiOs and used some of the info I gathered from this page to get my voice mail working now! To set up my voice mail I called my phone number (from the house phone), then pressed * when the automated system picked up...Your prompted to use a 4 digit pass code, which is the last 4 digits of your phone number (worked for me). From there I listened to the prompts and created a new "4 digit pw" as well as a "name password" by the end of the cycle. It then allowed me to listen to the messages on the phone and delete them! Phone finally says ready on it.
6answers
"New Voice Mail" stuck on screen.
Called GE. Here's what's happening (at least with my phone). I use VONAGE as a carrier. VONAGE's package includes voicemail. I have my VONAGE voicemail account set up to take any call that comes in if the answering machine on my GE phone does not pick up -- for instance if I'm on the phone and I do not "flash" over to the incoming call, that caller will eventually be sent to my VONAGE voicemail where they can leave a message. (Otherwise I would either take the call, or, if not already in use, the GE phone/answering system1.gif would simpy take the message.) This GE phone is commucating with my VONAGE account and letting me know that I have a mesage in my VONAGE account voicemail. All I have to do is either go online and delete the messages (after listening to them of course) and refresh the page. Once the messsages are deleted, the carrier lets my phone know the messages are gone and the NEW VOICE MAIL prompt on the handset disappears. I suppose I can do it by listening to the messages by calling in and deleting through the touch pad on the phone as well.
Top RCA Lands Phones Experts
k24674
SmartAviator
SmartAviator
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
