SHX45P05UC60 door opens too far (kids, husband, bosch...who to blame?) Is there an adjustment for door hinge tension?
You have to change the springs at the bottom back.It; s easy.You must buy the item 0509 at this page or anyother you like http://www.searspartsdirect.com/partsdirect/part-model/Bosch-Parts/All-Products-Parts/Model-SHX45P05UC60/1794/0130000/1010702P/00005?blt=06&prst=&shdMod=
Then you must access the bottom side of the base of dishwasher and with a screwdriver pull off the old springs.After this you will see a cordon that you must remove it and connect this to the new springs.
SOURCE: Door Tension
just about the most difficult job to do on a dishwasher, not normally a job for the home mechanic, i am an appliance engineer of 20 years and often shy away from jobs like this,
there is often no adjustment, the hinges are sprained, more often that not by people either putting weight on the door to stand back up, or children climbing on to get higher
the only thing i think you can do is to check the springs are in place and nothing is broken or just come off that can be put back?? sorry
SOURCE: Hello, My husband bumped
THE DOOR NEEDS TO BE RESET IN ITS POSITION.THAT A REPAIR MAN CAN DO BEST YOU GET THE AXPERT IN TO ASSIST YOU.
GOODLUCK.
MOHAMED
SOURCE: washing machine door tension too great
You need to pull the dishwasher out slightly to get to the top panel. On there you will see two screws attached to some cables. Release the tension on the cables by screwing the scres back in to make the cables appear slightly shorter. Ensure both cables are close to the same tension, and make sure that you do it with the door attached to get the proper weighting.
SOURCE: how do i adjust the tension of the door hinges on
you cant you only can change the springs. probably one is broken
