kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower Engine Motor () Logo
ben ebert Posted on Sep 05, 2013
My 23 horse kawasaki bake fires when warmed up under a little load like going from forward to reverse or turning while cutting grass why
jason
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 49 Answers
  • Posted on Sep 14, 2013
jason
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
49
Questions
6
Helped
9747
Points
72
Might have bad gas or dirty spark plug check the gap on your plug and maybe the coil
2 Related Answers
Anonymous
  • 927 Answers
  • Posted on Sep 10, 2011
SOURCE: My 23 hp Kawasaki engine
When it begins to stall, loosen the gas cap. If performance improves, clear the gas cap vent holes.
Gary
Anonymous
  • 6468 Answers
  • Posted on Jul 10, 2012
SOURCE: does a 23 horse kawasaki lawn engine have a timing chain? what would cause a bent push rod
a lot of the over head valve engines run into this carbon build up on the valve stem will bend a push rod
My mower will not go forward or reverse
..it won't go forward or backwards??.. what..??...HOW are you going to cut grass??.. cutting in one spot doesn't help much huh..??... Is this a riding mower?.. 0-radius turn?...
Seriously.. since we do not know what type of mower you have.. here goes: Take it to a qualified professional.
1. The drive chain is broken or come off the sprockets.
2. Your drive has failed.
Sep 08, 2017 • Garden
Toro Timecutter MX5050 74770 won't move forward or reverse.
find a breakdown of the parts diagram. that may help.
Sep 25, 2016 • Toro Garden
Is there no reverse, goes forward but won't go in reverse
Outboard won't go into reverse ?? - General Discussion Forum ' In ...
www.in-depthoutdoors.com > ... > General Discussion Forum
Aug 9, 2006 - 8 posts - ‎7 authors
There's 2 cables that go into my outboard. ... It would have forward just fine but it would not shift into reverse. Assuming it's a wheel boat does the throttle handle go intoreverse but reverse doesnt work or does it not even ... Here are instructions to recover your old idofishing.com or idohunting.com account:.
Boat won't go in reverse - Lake-Link.com
www.lake-link.com/forums/boats-motors/.../Boat-wont-go-in-reverse
Sep 23, 2013 - 4 posts - ‎3 authors
Fishing Boards - Boats & Motors: Boat won't go in reverse. ... Forward seems to be working OK, but reverse just won't engage. ... I'm not sure if this is something at the throttle control end or something wrong at the motor. Any thoughts ... Looks like there'sa piece missing that's supposed to hold that in place.
Help! Will go in Reverse but not Forward gear! - The Hull Truth ...
www.thehulltruth.com/boating.../526873-help-will-go-reverse-but-not-f...
Jul 30, 2013 - 8 posts - ‎5 authors
Whether you're researching a new boat, or are a seasoned Captain, ... and it was notengaging fully into forward gear, but into reverse just fine. ... I'm a little dumbfounded as to why it will lock the prop when it's not running, but won't go into forward gear when it is ... While your there, change out the bellows. Mercury 125 won't go into reverse - The Hull Truth ...
Mar 17, 2014
Mercury 25 Horse Won't Shift into Reverse
Apr 5, 2009
90hp Yamha won't go in reverse & more - The Hull ...
Oct 4, 2007
Boat wont go forward or reverse - The Hull Truth ...
Jun 6, 2006
More results from www.thehulltruth.com
Dec 16, 2015 • Boating
Toro zero turn mower with Kawasaki 691v 24.0 horse motor starts cutting out and smoking after running for about 20 minutes.
Check the oil to make sure you don't have gas getting in your oil. If that's not a problem then you may have a leaking head gasket.
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
My Husqvarna YTH21K46 start's up good, But will no go forward or reverse. Iwas cutting grass for about 15 minutes, then the clutch pedal began shaking, but still going forward and reverse. i decided to...
There should be a pulley that the brake/clutch petal pulls against to disengage. You could have a problem with that. You will have to turn it by hand to check and see. Check the main drive belt while you are in the area. It may be helpful to remove the deck so you can slide up under there get a good look.
I hope this gets you going.
1helpful
I was mowing the grass, turned around to go back down to cut a new rpow, and lost all ability to go forward or backwards. Pedals seemed tosink a little lower, and there is a lovely grinding sound...
hydrostatic transmission has reached the end of its life. Call a dealer and get a price to repair, then contrast that amount with the cost of a new mower. Those transmissions are not cheap, you may find folks selling them NOS on eBay, certainly worth a few minutes googling around before you lay down the bucks. Do not buy a used transmission.
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Husqvarna yth2443t little or no movement
make sure the trans. linkage can operate freely. Had the same problem,it was just a build up of grass and dirt.
Top kawasaki Garden Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
