Computers & Internet Logo
A
Anonymous Posted on Sep 05, 2013
Intel pentium dual core inside hcl motherboard cd laptop
Where can i locate the cmos jumper on the motherboard.hcl duo core.thank you
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Oct 10, 2007
SOURCE: really disappointed with dual core
You can buy a 3.02 pentium 4 processor and need not change any thing else. On the other hand try changing your hard disk with a one with smaller capacity such as 80 GB make it primary with the windows partition not exceeding 15 GB . Make this drive (80 GB )primary and other one secondary.Increase the virtual memory size of your system and for sure you wont need to buy any thing or be depressed anymore.
RICHARDM69
Desktopsbyduck-Computers
  • 1061 Answers
  • Posted on Dec 13, 2008
SOURCE: processor swap
Not always but it appears as though this swap will.RICHARDM69
Anonymous
  • 565 Answers
  • Posted on Jan 27, 2009
SOURCE: my asus p5gc-mx motherboard sound driver cd is missing
Killer rig :-) Do you have it connected Raid 0? Yes, here ya go:
http://support.asus.com/download/download.aspx?SLanguage=en-us
This is for XP. If XP is not your OS, then select your OS.
Anonymous
  • 110 Answers
  • Posted on Aug 16, 2009
SOURCE: INTEL PENTIUM DUAl core E2140 MOTHERBOARD CD
what is ur mother board's company please send me *********** board's company.
Alun Cox
  • 2679 Answers
  • Posted on Sep 06, 2009
SOURCE: CONFUSION WITH INTEL CORE DUO AND INTEL PENTIUM DUAL CORE!
You are worrying about nothing.
Intel Pentium Dual Core and Intel Celeron Dual Core are both Intel Core Dual processors.
The performance rate is mesured compared to a single core processor so your 2.2GHz dual core will do the same amount of work as a 4.95GHz single core.
Testimonial: "WAIT A MINUTE I NEED ANOTHER REPLY!SO WHAT YOU'RE SAYING IS MY PENTIUM DUAL CORE CAN RUN GRID?"
Best compitable intel core two duo processor for mercury PI945GZD mainboard
Hello here is the homepage:
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=718#
The mainboard is socket LGA775 for latest Intel Core 2 Duo(E4400/E4300)/ Pentium(Dual- Core inside)/ Pentium D / Pentium 4 / Celeron D processor/
Good luck
3helpful
I just need to figure out what the socket type this motherboard has for the processor so that I can find what processors I can upgrade my computer with. It's a g45t/g43t AM 3 V: 1.1 motherboard made by...
The socket type of ACER G45T/G43T - AM3 V1.1 motherboard is LGA 775. Here are the compatible processors you can use for this motherboard :
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
2answers
I want to know that did intel d945gcr supports core 2 duo processor...............plz
This mother board will work if we have a compatible processor like Intel Core2 Duo, Intel Pentium D, Intel Pentium 4.But the processor should be greater than 2.99Ghz if the processor is less than this then it will to work.Dual core processor means there will be two processors working
The detailed specifications of the new Intel D945GCCR Motherboard are:
  • Form Factor:MicroATX
  • Processor:Intel Core 2 Duo, Intel Pentium D, Intel Pentium 4 and Celeron D processors in the LGA775 package
  • Supported System Bus:800 MHz / 533MHz
  • Chipset:Intel 945GC Express Chipset with ICH
  • Supports Hyper-Threading Technology
  • Graphics:Intel Graphics Media Accelerator 950
  • Graphics Connector:One PCI Express* x16 graphics connector
  • Memory Support:Dual-channel DDR2 533 / 400 MHz, 2 DIMM slots (2GB Max)
  • Expansion Slots:Two PCI connectors
  • One PCI Express* x1 connector
  • Audio:Intel High Definition Audio with 5.1 Surround Sound
  • USB Ports:Eight Hi-Speed USB 2.0 ports (4 back / 4 front)
  • Storage One IDE (ATA 100/66/33)
  • Four Serial ATA ports (3.0 Gb/s)
  • On-Board LAN:Intel PRO 10/100 Network connection
  • Warranty:3 year limited warranty
Hope that solve your problem!
Thanks for using Fixya!
2helpful
2answers
Can intel dual core e5400 work on my motherboard?
Yes you can.
Your motherboard is LGA775 socket and supports the folowing processors:
Core2 Duo / Pentium Dual Core (yours) / Pentium D / Pentium 4 / Celeron 4xx series/ Celeron D.
1helpful
1helpful
2answers
Need a prossesor for motherboard
You can also use any other intel 775 socket processor as well. The dual cores are at the top of the list for performance that are compatible with that board, but if you're looking for a cheaper solution, I have that board with a 3GHz pentium 4 and it runs great. Here's a list of all the processors you can use.
Intel Pentium 4 (2.66 - 3.80 GHz)
(3.20 - 3.73 GHz)
Intel Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 2.80 GHz)
Intel 'Core' Celeron (1.60 - 2.40 GHz)
Hilw,, what is the difference between atom and intel core duo processor??
The Atom is a low power single core processor, it is roughly same speed and similar microinstruction set as a pentium 4 single core, and uses far less power and produces less heath than a regular pentium 4.
The intel core duo is a dual core processor that uses 64-bit core duo (dual cpu inside) processor.
Dell Dimension 9100 - Motherboard & Compatible CPUs
Intel Pentium 4 Socket-T (LGA775) with Hyper-Threading or Dual-Core support, cache 1MB or 2Mb for 9100, or just 2Mb cache for 9150. I know of some of these machines having pentium D installed but I do not believe a Core 2 Duo is an option, whereas Dual-Core is. Good Luck!
Difference b/w Core to duo and daul core
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper.
they both are dual core CPUs.
I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
2helpful
4answers
Cpu enquiry
There really is no difference, there are differences in the E numbers though. Those are specificallt about it's GHz's, it L1 and L2 cache.
Though Intel Core 2 Duo is the same as Intel Dual Core. It's just a different name. This confusion is caused because of Intel changing the names of it's processors series. The Pentium brandname for example is gone. Intel Pentium Dual Core is now called Intel Core 2 Duo.
I hope this answered your question.
Greetings,
DarkNeogen.
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
