Question about Lexar LDP-200 MP3 Player
Firmware ver0.5 is there updated firmware version for lpd-200
    Top Expert:
  • Lexar Master
  • 76,036 Answers
Yes. There is other 2 new updates.
Posted on Aug 30, 2016
SOURCE:
Bernina Artista 200. Recently upgraded software to Version 7. Now my machine will not recognize my Bernina Mini CD drive or USB stick. The area on the machine itself that shows the "plug" for the...
You will need to find who is the maker of the CD player and what model it is then do a internet search for the newest driver, then install it on your PC.
Jul 18, 2014 | Bernina artista 200
/usr/libexec/cups/backend/lpd failed
This sounds like a printer issue rather than something wrong with your Mac. When you refill your printer ink cartridges the ink level setting won't change, and if you let the ink level go down too far before refilling the printer marks the cartridge as empty and locks it out. (something like that)
Try this... It should work on most newer model printers.
Shut down your Mac. (important) Turn the printer off and leave it off for one or two minutes. Turn it back on and wait until it goes through all of its whirring and clicking and chugging start-up noises. When it's quiet you should end up with a flashing "E" or an upside-down "u" on the display. Find the Reset or Stop button on the printer and hold it down for 6 seconds. The display should clear and show the number "1".
Turn on your computer and print. If it works, you're done.
If that didn't work pull down the Apple menu and choose "About This Mac". If it says Version 10.6.8 you're about to spend $29 because the message "/usr/libexec/cups/backend/lpd failed" was common with that version of OS X, and that was the last version of Snow Leopard 10.6. Click the "Software Update..." button which will open the App Store. Shell out your 29 bucks for Mavericks OS X 10.9.
The only other solution would be to replace "lpd" from a different computer that's running 10.6.7, which is doubtful. (unless you have a backup)
Good Luck!
Oct 23, 2013 | Apple MacBook Pro Laptop Computer with...
Network challenges
Sounds like your version of windows may not support your printer and or the drivers need updated. Possible firmware update as well
May 03, 2012 | Minolta bizhub 200 All-In-One Printer
Canon IPF8000..... i need to override the "ink
Before removing the used print head, be sure to update the printer?s firmware version with the included CD-ROM. An error message will be displayed on the printer?s display when the new print head is installed without updating the version. In this case, re-install the used print head and update the firmware version.
Updating the firmware
1. Turn on the power of the printer. Check that the printer is online.
2. Run the file setup.exe in the FirmUpdate folder in the CD-ROM. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from Programs in the Start menu.
4. By following the instructions, update the firmware version.
2. Select the OS89 folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate]. [GARO Firmware Update Tool] will be installed.
3. Run [GARO Firmware Update Tool] from [Applications] - [GARO Firmware Update Tool] folder.
2. Select the OSX folder in the FirmUpdate folder in the CD-ROM, and run [GARO FirmUpdate].
Precautions when updating the firmware version
- Use [GARO Firmware Update Tool] after checking that the printer is online.
- Do not turn off the power of the printer while firmware data is being transferred.
- If the printer?s firmware is already the most recent version, the Status of the target printer will be displayed as ?Update Finished? when using [GARO Firmware Update Tool].
Techbelkin
Dec 13, 2010 | Canon imagePROGRAF iPF8000 Printer
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
Why haven't you found solutions for the posts above???
Hello joe_east,
[Update]
Have a great day,
martyshaw152
I need to update the Belkin Router for Wildblue.net
Contact Belkin Tech Support At Toll Free Number- 1-800-585-2494
Apr 22, 2010 | Belkin F5D8236-4 Router
Have accidently wiped mapping from garmin sat nav
I can help you fix your Garmin Nuvi 200.
The error message you are receiving about maps is actually a sign of a firmware corruption problem, which just happens from time to time with electronic devices. Updating the firmware of your nuvi will replace the corrupt firmware.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software. Occasionally a nuvi 200 will also need a Hard Reset (preceded by a favorites backup) to bring it back to 100% operation.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 09, 2010 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 200
To view the current firmware version, complete the following steps:
  1. Turn on the GPS.
  2. Switch to the tool kit page by touching the tool symbol on the buttom row.
  3. Touch "Settings".
  4. Touch "System".
  5. Touch "About"
  6. Thesystem will display the firmware version at the top ("SoftwareVersion"), the unit ID on the second line, followed by variouscopyright information.
  7. Touch "Back" to return to the previous page.
For online updating you must have Webupdater
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
After installing WebUpdater once from the Garmin website, perform allfuture software updates from your computer. Simply connect yourcompatible Garmin device to your computer, then run WebUpdater fromyour computer's "Start Menu" by selecting "Start", "Programs","Garmin", and finally "WebUpdater".
Attention! It were cases that unit software newer than on Garmin site and it were losings of local language support after online updates. You must deside before do you need these changes of firmware or not so important.
Sep 27, 2008 | Garmin nuvi 200W GPS Receiver
Lexar LDP-200 MP3 Player Logo
Top Lexar Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Lexar Audio Player and Recorder Expert? Answer questions, earn points and help others
