Canon LASER SHOT LBP-2900 Printer Logo
A
Anonymous Posted on Sep 05, 2013
This test page briefly demonstrates the printer's ability to print graphics and text on hp 1020
  • NP Singh
    NP Singh Dec 06, 2021
    uninstall printer driver fully uninstall and update printer driver by device manager in windows10.. 100% solve
mani
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 11, 2017
mani
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13558
Points
29
Robbie Goodwin
Level 2:
Sergeant:
  • Expert 384 Answers
  • Posted on Mar 19, 2015
Robbie Goodwin
Expert
Level 2:
Sergeant:
Answers
384
Questions
0
Helped
87770
Points
989
Is that not what it's supposed to do?
Where is the problem?
5 Related Answers
Anonymous
  • 741 Answers
  • Posted on Jan 01, 2009
SOURCE: My Pages Are Printing Off The Page
If you still have your printer manual. Look up the instructions for calibration. That will fix it.
Anonymous
  • Posted on Apr 26, 2008
SOURCE: Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
MUKHTAR
mukhtar21 shaikh
  • 2022 Answers
  • Posted on Sep 22, 2007
SOURCE: won't print text or test page
try with diffrent printer driver and see. bye
hamster47
  • 739 Answers
  • Posted on Sep 10, 2009
SOURCE: printer prints color, but not black even with new cartridge
First thing to do is a head clean then do a test print. Do you see any of the black lines?
If not, don't do a deep clean as this uses up too much ink. Remove the ink cartridges and then remove the print head unit.
Run the print head under a hot tap for a few minutes until all the run off is clear. Take it outside if you can and shake it dry vigourously. You can use paper towel if you like but try not to wipe across the nozzles. Make sue the contacts are all dry and refit it to the printer. reinstall the ink cartridges and print a few test pages - the first couple may well be wasted but then it should start to print properly.
Is the black still missing? If it is do another head clean and another test print. Any improvement? If you start to see some black do some more head clean routines and it may well come back to normal. If on the other hand you see no trace of black at all, it could be that the print head is worn out and needs replacing.
This printer is now of an age where the print head may well be failing. Mine had to be replaced last year as one of the colours stopped printing.
The head is not exactly cheap - but it's cheaper than buying a new A3 printer.
Anonymous
  • 2306 Answers
  • Posted on Sep 25, 2009
SOURCE: Will not print black text.
You need a new printhead, QY6-0061-000, around $60.00
Hp 1020 laser printer output is blank
Have you replaced the cartridge? It is probably causing the issue you have. Toner will compact if it sits for long periods of time.
Text and graphics not printing complitely Half Image and Half take printing from HP 1020 printer. If I give Print command only two or three line print come on paper after that four to five line black again...
Try another cartridge as it sounds like your drum is bad. If you measure the distance between the start of two sets of print I can tell you exactly what is wrong.
Printing Blank page
1: try another toner cartridge (or possibly pull the seal from the side of the cartridge you have just installed)
2: If it's not the cartridge causing the problem take it back - it has 1 year warranty.
HP Laserjet 1022 printer
I found what might be the solution to this while searching for a problem for another printer series on HP's site. Go to the Printed Page Is Different Than What Appeared on Screen page and scroll down to "Missing graphics or text, or blank pages"
2answers
Printing graphics
Is it outside the normal printing area? It seems strange-Could there be something stuck in the machine over there? or an ink blob on the paper roller?
2helpful
How can i get the list of the count the printing page numbers day to day
go in start then printer and faxes and then goes the properties of hp lj 1020 and give one print text page after the page will printing goes in advance then printing default then basics and then about then display the current page count from your printer you can note down this is in eveary day and then your can manage your print count
HP officejet 6110 all in one
hmmm...odd to say the least..try this first..
print a test page from the printer settings page.
that should have text and graphics
2answers
Regarding printing of envelopes.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00602236&cc=us&lc=en&dlc=en&product=439320&dlc=en&lang=en
http://h10061.www1.hp.com/ccsearch/search?ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=439428&productBigSeriesOid=14924&spid=439320&pname=HP+LaserJet+1020+Printer&opname=HP+LaserJet+1020+Printer&pname_desc=HP+LaserJet+1020+Printer&st=1&ptype=consumer&stype=pn&qry=printer+doesnt+print+the+first+time&translate=&iqry=&ctflag=&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&spname=HP+LaserJet+1020+Printer&cqry=&uqry=
old marine
old marine
ZJ Limited
ZJ Limited
