LCD screen is black when taking pictures. The menu works fine, the lens comes out and everything looks like it will work but the pictures are black on the lcd screen and on the computer when loaded on the computer.
when i do turn it on and try to take a picture with the screen being black everything freezes and i can not do anything it was working fine at first then stopped workingwhen i do turn it on and try to take a picture with the screen being black everything freezes and i can not do anything it was working fine at first then stopped working
You can't post conmments that contain an email address.
how or where exactly would you recommend some to go that is having this issue with their camera?how or where exactly would you recommend some to go that is having this issue with their camera?
Hi there your lcd screen is fine but the Chances or damaged are lens or sensor of lens or circuitbord disconnect from the lens sensor. All cases you need to visit service center. Thanks.
Maybe the shutter got wet and sticky. You can try look into the lens then press shutter button to take picture. If you don’t see the movement inside the hole, the shutter doesn’t open, it will take black picture.
I have seen this several time the lens cable can cause this issue it could also be the back light or the LCD I repair these all the time If you do not fill comfortable replacing the parts you can go to www.digitalcamrepair.com if you need further assistance.
No I don't believe it is your shutter, more than likely it is a LCD Screen problem. I would suggest you take your camera back to the shop where you purchased the camera and have it serviced under warranty.
I had a customer with an Optio 550 come in and it looked like every shot was taken through 'venetian blinds' and the problem was with the LCD Screen and the camera was sent back to Pentax and repaired under warranty.
