click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
if your computer came with a motherboard disc the sound
drivers could be on it
manager scroll to sound,video and game controllers you might see a yellow
question mark? Right click to reinstall drivers
Click start control panel administrive
tools computer management device manager scroll to display adapters + to expand
you might see a yellow question mark ? or exclamation mark ! or a red x right
click select reinstall drivers
also
One bad lead can cause a computer to continue on a cycle
or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical
extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make
sure they have a secure connection and are not faulty or just replace them
there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch
floppy have secure connections and are not faulty even the electic extensions
or just replace them they could be faulty a computer needs its connections to
continue its cycle and to have an end so any faulty leads will end up with a
computer error
Click start
control panel administrive tools computer management device manager scroll to
display adapters + to expand you might see a yellow question mark ? or
exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display
adapter restart your computer then reinstall the display adapter and its
drivers this would apply to the sound video and game controllers to hope this
helps
