Graco Ultra Deluxe 5-in-1 4605 Crib Logo
A
Anonymous Posted on Sep 04, 2013
Stretcher bar missing - Graco Ultra Deluxe 5-in-1 4605 Crib
2answers
Putting new sway bars onto 98 tahoe 4×4 LT . driver side is in cant get passgner side to go in
You have to jack up that side to get the sway bar link in if that's what you mean you could do the other side because both were disconnected bUT now one side is so you have to relieve both sides of pressure jack ed on stands from the frame then raise the problem side up from under the control arm I think that this is what your asking if not please post back again in comments with exactly what your having trouble with and please be precise I can't just turn to you and ask you a question or look myself because obviously me and everyone else are not there ok thanks stephen
We have a striker 1005 stretcher it has lost hyd fluid over time and cannot be raised to full height how could I fill it for use until new parts come in
SADLY Stryker seems to use their service and "manuals "
sections to FURTHER ADVERTISE their EQUIPMENT...
I was hoping to find, 10W oil, dextron... etc...
(but alas.. I found NOTHING (sorry)).
Contact them directly at
Phone:
800-STRYKER (787-9537)
Option 1 for Field Service
Option 2 for Tech Support Fax:
866-787-9095
Email:
[email protected]
MISSING PART TO SWING SET
The manufacturer on the box, or the store where you bought it. If not google metal swingsets, find one that looks like yours, & contact them about ordering a bar.
Nov 08, 2013 • Toys
1helpful
How can I make a really cheap sofa table?
Cut ListCut List: A) 4 - 1x3 @ 29 1/4" (Fronts and Backs of the Legs) B) 4 - 1x2 @ 29 1/4" (Sides of the Legs) C) 2 - 1x3 @ 10" (Side Support) D) 1 - 1x2 @ 37" (Stretcher) E) 2 - 1x3 @ 37" (Side Trim for the stretcher) F) 2 - 1x4 @ 10" (Side Apron) G) 2 - 1x4 @ 37" (Front and Back Apron) H) 1 - 1x12 @ 48" (Base for the top) I) 2 - 1x4 @ 11 1/2" J) 1 - 1x12 @ 41"
Step 1
Download Original]'>untitled-3%20(15).jpgConstruct your legs by nailing through the 1x3 legs into the edge of the 1x2 legs with 2" nails and glue. The legs will be positioned with the 1x3s to the front, 1x2s to the side, as shown in the diagram.
Step 2
Download Original]'>untitled-4%20(14).jpgStart by marking each of the legs 5" from the bottom of the board. This will be the bottom of the side support, C. Nail C to the legs, using 1 1/4" nails and glue, from the inside.
Step 3
Download Original]'>untitled-5%20(13).jpgNow add the stretcher, D, centering D on the support, C, but keeping the top edges flush. D will lay flat, with the wide side up. This is demonstrated above. Use glue and 2" nails, nailing through the support, C, into the end of D.
Step 4
Download Original]'>untitled-6%20(9).jpgAdd the side trim pieces, E. First, nail through the supports C into E, using 2" nails. Then nail down the length of the stretcher, taking care to keep the top edge of the stretcher (D) perfectly flush with the top edge of the stretcher support (E). Use glue and 2" nails.
Step 5
Download Original]'>untitled-7%20(8).jpgNow use the 1 1/4" nails to nail through the back of the side apron pieces, F, into the legs. Use glue. Keep top edges perfectly flush.
Step 6
Download Original]'>untitled-8%20(7).jpgDo the same for the front and back apron pieces, G, as shown above. Nail through G into the legs using 1 1/4" nails and glue. Keep top edges flush. Take a minute to check for square
Step 7
Download Original]'>untitled-9%20(7).jpgNow add the base top, piece H. Keep the front and back edges flush with the legs, but let the sides overhang 4" on either side. Nail into the legs and the apron using 2" nails and glue.
Step 8
Download Original]'>untitled-10%20(6).jpgUse glue and 1 1/4" nails to attach the breadboard ends to the base top. Keep all outside edges flush.
Step 9
Download Original]'>untitled-11%20(5).jpg I recommend not cutting the final piece, J, unitl you have taken an exact measurement. Add the final piece, using glue and 1 1/4" nails.
Finishing Instructions
May 29, 2012 • Furniture
May address bar was missing
Check Menu bar->View and select the missing bar.
How do I get the headliner down on an 89 Volvo 240 wagon, so I can access tailgate wiring harness?
with great difficulty,normally these things have plastic push studs if its the solid type ,but if its the material type with metal bar stretchers then the edges are pushed into a sort of groove in the edge of the roof ,and if its old as you try to pull it out it rips apart.Best of british with it
18helpful
Recovery Disc Error 0x400110020000100A
If you got this error message when you tried to replace or upgrade the HD, take a look at the hard drive you took out of the computer. Look at it closely. Is there a "stretcher bar" across the contacts? Take the stretcher bar off of the old HD and put it on the new HD. I did so after much consternation and had no more error messages. I do not thank HP for the aggravation the lack of info on this on their support website, or the fact that the HD had to be replaced well before its time was "due".
Top Graco Baby Gear Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jay Finke
Jay Finke
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
