SOURCE: Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
SOURCE: Stops mid-cycle (all cycles)
Hello welcome
First I would recommend putting the washer in a diagnostic test mode to
see if there is a stored error code indicating where the failure is.
Once the cycle starts, it should progress on its own to the end of the
cycle without needing any assistance. All you can really do is make
sure the water supply (hot & cold) is on & the drain hose is
not kinked or restricted. Here is a copy of the service manual showing
the test modes & error codes. You can order the owners manual with
part number 8566938 at www.sears.com
Thank you
Huum
Please remember to leave a solved rating before you sign off
SOURCE: Maytag MDB7130AWB dishwasher blows circit breaker.
These have been known to leak water into the door panel. If so the water can cause a short. Your breaker is keeping the machine from lighting up. Check any seals that may have been braeched in the door. Start at the dispencer latch
rubber.
SOURCE: Maytag dishwasher.Loud humming noise, wash cyle,at beginning
Is the water filling up and then draining out? Mine did this and a part was broken inside the unit. The part was five dollars and called a lifter. I fixed it myself.
